Another generator brush holder question
70shovelhead
First Name: Preston
Last Name: Wells
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
Board Member Since: 2008
Post by 70shovelhead » Tue Aug 06, 2019 5:25 pm
So I started into the generator for the TT. It turned freely and would even motor with 6v applied. The armature checked out ok on the growler so it is a rebuild candidate. But after removing the brush plate I noticed the insulated brush mount was loose, actually to the point it would pull out of the holes in the plate. Has anyone had luck remounting a brush holder? I know Langs sells the plate assembly.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
Re: Another generator brush holder question
Post by RajoRacer » Tue Aug 06, 2019 5:36 pm
Start with a new repro or good used one and drill & tap to a # 4 or #6 brass screw - I've done several that way and I also have rebuilt ones available - drop me a note.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Tue Aug 06, 2019 5:41 pm
Preston,
Here is the way I do it.
The order of the photos is up side down.
Good luck
Andre
Belgium
Last Name: Hatch
Post by Dan Hatch » Tue Aug 06, 2019 9:18 pm
Do all the time. Dan
