Hi Low Head
JEC
Last Name: Cox
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1925 Pickup
Hi Low Head
Post by JEC » Sat Jan 19, 2019 7:40 pm
Can someone tell me if my15's head is a Hi head or a Low head?
Kerry
Last Name: van Ekeren
Re: Hi Low Head
Post by Kerry » Sat Jan 19, 2019 7:53 pm
It's a low head.
JEC
Last Name: Cox
Re: Hi Low Head
Post by JEC » Sat Jan 19, 2019 7:55 pm
Thank You Frank,
How can you identify the difference?
Re: Hi Low Head
Post by Allan » Sat Jan 19, 2019 8:49 pm
John, it looks like a low head. with Frank's experience, and that of many long time T owners, things get to have familiar proportions. You can double check his opinion by taking out one spark plug. Bend a piece of wire into a U shape about 3/8" wide at the bottom and put it through the plug hole. you should be able to feel a ridge around the bottom of the plug hole. High heads do not have this ridge.
Hope this helps.
Re: Hi Low Head
Post by DanTreace » Sat Jan 19, 2019 9:35 pm
Another fast way to tell is viewing the bolt ends holding the upper radiator outlet casting.
On a low head all the threads of those bolts can been seen protruding.
A high head masks the lower portion of those exposed bolt ends.
Would be very noticable on your low head, except the bolts aren’t stock Ford fasteners but are modern short ones. ;)
Nv Bob
First Name: Bob
Last Name: Middleton
Re: Hi Low Head
Post by Nv Bob » Sat Jan 19, 2019 11:08 pm
1/4"
