1916 turtle deck
Randall strickland
Topic author - Posts: 158
- First Name: Randall
- Last Name: Strickland
1916 turtle deck
Is there metal on top of the boards where turtle deck sits on on a 16 roadster or does it just sit on the wood?thanks
MWalker
- First Name: Mike
- Last Name: Walker
Re: 1916 turtle deck
It sits on the wood, no metal there.
Erik Johnson
- First Name: Erik
- Last Name: Johnson
The deck of the roadster on which the trunk sits is covered with sheet metal.
The floor of the trunk itself is wood.
Randall strickland
thanks fellows!
nsbrassnut
- Last Name: Lee
It can depend on the manufacturer of the turtle deck.
Some are wood frame only and the metal skin of the body becomes the floor. Others have a rabbit in the wood framing and a wooden floor.
Mine was wood frame only and I added a wood floor on top of the framing instead of dumping things on the painted metal of the body deck.
This was discussed previously here and you may find out more with a search of older postings.
Drive Safe
Jeff
Nova Scotia
Drive Safe
Jeff
Nova Scotia
I have no knowledge of the 1916 turtle deck, but on my original1913 with a Fisher body, the sheet metal goes all the way to the back body sill, from the tack strip. The lower framework of the turtle deck is rabbeted, as mentioned to accept a wood floor. I don't recall if it was 1/4 or 3/8's
MWalker
- First Name: Mike
- Last Name: Walker
I guess I was mistaken. Eric J. knows more about T's than I do, for sure.
- Last Name: House
Eric’s description holds true for my ‘14 runabout.
Randall strickland
Thanks for the pictures Bob
