Some speedometer help please
KenHaverhill
Topic author - Posts: 111
- First Name: Kenneth
- Last Name: LeBlanc
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
I am installing what I believe to be a model 160 Stewart speedometer in a 23 touring with 30x3.5 wheels .what is the correct tooth count on the 2 gears at the wheel and is the pivot a 1 to 1 ratio of different? Thanks in advance
Re: Some speedometer help please
Your best bet is to obtain a copy of Russ Furstnows speedometer book. Your wheel gear will be 60 teeth, and the fiber gear will be 16, and the swivel will be 2 1/2 rh.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
The road gear, which is mounted to the wheel, is a 60 tooth 8 pitch gear. The pinion gear, which is attached to the swivel joint is a 16 tooth 8 pitch gear. The ration at the swivel joint is 2.5:1. I hope this helps.
Russ Furstnow
Russ Furstnow
KenHaverhill
Mark Osterman
- Last Name: Osterman
Be very careful when you buy a swivel. Make sure it is tight with no slop and the right ratio! You can make very expensive purchases on ebay and car shows ... that are mistakes.
