Motor knock
Topic author - Posts: 32
- First Name: Harold
- Last Name: Chambers
- * REQUIRED* Type and Year of Model Ts owned: 1925 fordor. 1923 touring
Motor knock
I have a 25 t about 35 mph when the motor is running free I have a clapping sound when I give it gas the noises goes away when motor is holding back no noise. I have plastic gauge rods and mains they r within spec. Could it possible be a pistol slap? it has .040 over I put new pistons and rings in it.I have drove it several thousand miles sense then it's no worse or better. that noise is driving me nuts. Thanks in advance Harold.
- First Name: Philip
- Last Name: Thompson
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
Re: Motor knock
Mind tends to make that sound when I have the spark too advanced. My chapter
Bought one of the solid-state coil testers we put new capps. And points in the coils and set them.
Now I don't need as much advance. Philip
- Last Name: Harris
- * REQUIRED* Type and Year of Model Ts owned: 1913 Mountain Wagon
Re: Motor knock
Some times the connecting rods can get twisted and will cause a knock. We had a 1913 that had that issue. Straightened the rods and the knock went away.
- Last Name: Dow
Re: Motor knock
Harold, Do you by chance have an aluminum high compression head? I do and I had a very similar loud knock as you described. It drove me crazy trying to find the cause. It turned out to be pre-ignition engine knock. I found by running 91 octane and using a little less advance the noise went away.
Re: Motor knock
Don't have high compression head but have high compression pistons.I will try what you did.Thanks
- Last Name: Dow
Re: Motor knock
Harold, I bet you have the same problem! Hopefully, you can solve it as I did. Please follow up and let us know the result.
