Engine knock
John bevardos
Last Name: bevardos
* REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Engine knock
Post by John bevardos » Sat Sep 21, 2019 9:21 pm
Hi all, can't find my manual so I'm going to ask the professors here. Motor has a knock when it is just coasting not accelerating and not D accelerating. Number one rod was a tad loose could move it by hand so I remove to shims it's nice. Still had the knock as I drove it, shorted out all cylinders and when I shorted out number three, it knocked like crazy. What do you think it might be? Thank you, John
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
First Name: Henry
Last Name: Lee
Re: Engine knock
Post by Henry K. Lee » Sat Sep 21, 2019 9:29 pm
Bad Wrist Pin?
John bevardos
Last Name: bevardos
Re: Engine knock
Post by John bevardos » Sat Sep 21, 2019 9:41 pm
Hi Hank, was kind of thinking the same thing because the rod was nice and tight on the journal so I left it alone. Thank you, John
First Name: Henry
Last Name: Lee
Re: Engine knock
Post by Henry K. Lee » Sat Sep 21, 2019 10:00 pm
John,
Can you reach up there with a super long set of needle nose pliers to see if just by chance the bolt back out a little? It is tight in there but sometimes it can be retightened and the problem stops. Just saying.
Hope you Find It,
John bevardos
Last Name: bevardos
Re: Engine knock
Post by John bevardos » Sat Sep 21, 2019 10:10 pm
Thank you Hank, will definitely give that a try. John
