What are these?
AdminJeff
What are these?
They look like suspension parts and are new but I don't recognize them.
And body supports of some kind?
. Jeff
. Jeff
- First Name: Dallas
- Last Name: Landers
Re: What are these?
Jeff, the 1st photo is 26-27 T windshield risers for roadster or touring.
Not sure on second photo but looks like aftermarket shocks or overload springs.
Re: What are these?
Dallas is correct on both counts !
AdminJeff
Re: What are these?
I have a full set - front & rear but mine have ball bearings where yours have brass wear plates - I believe the perch was reversed like Hassler installation required and those work with the original springs - Dan T. most likely has an advertisement for them - I do too somewhere.
Re: What are these?
Here's a few adv. on these.
Have rear set only on the '23 cut-off pickup. Gives the wood bed a nice ride with loads, and kicks the frame up a tad.
On the front axle, have '26-'27 spindles that lower it, provides a nice rake to the chassis, truck like
This version on the rear , have large ball bearings on the leading edge to glide over the leaf spring. The flange keeps the spring stack in place as you remove the leaf clamp.
Re: What are these?
Thanks Dan !
Doug Keppler
- First Name: Douglas
- Last Name: Keppler
