I appologize as the photos I tried to post with this refuse to show unless listed afterwards as attachments. The forum error says they cannot read image dimensions.
I am finally starting work on the Omnibus. Up first is the Ruckstell I bought for it (see first attachment). Examining this all seems well, too much play in the shifter arm may require a bushing. The ring gear looks good (attachmnet second) but is greasy, dirty. I am wondering if it can be cleaned out closed... no I better open it and inspect.
But first I start wire brushing rust and crud off the outside when I hear a "klunk" when I turn it over. A thrust washer dropped out and is shown below (attachment third). Well I am planning on using bronze washers so I am hereby offering this babbit bearing 1/3 off !!!).
The fellow who sold me the Ruckstell obviously left that lower torque tube and drive shaft out in the rain, it shrunk! Even the pinion shrunk... only ten teeth. (attachment last)
Tongue firmly planted within cheek,TH
Thrust washer for sale, 1/3 off
Thorlick
Topic author - Posts: 214
- First Name: Terry
- Last Name: Horlick
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
- Attachments
- "New" Ruckstell, large drum
- r3.jpg (29.33 KiB) Viewed 2863 times
- Ring Gear
- r1.jpg (21.95 KiB) Viewed 2863 times
- Thrust Washer
- r2.jpg (29.72 KiB) Viewed 2863 times
- Misc. Parts
- r4.jpg (11.8 KiB) Viewed 2863 times
- Last Name: Hjortnaes
Re: Thrust washer for sale, 1/3 off
This belongs in the classified!
Mustang1964s
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Doug Keppler
- First Name: Douglas
- Last Name: Keppler
Terry, love your profile picture
1924 Touring car
There's No Substitute for Proper Lubrication
