Coil tester
Topic author - Posts: 20
- First Name: Tom
- Last Name: anderson
Coil tester
does anyone have any information on this tester
- First Name: BOB
- Last Name: CASCISA
Re: Coil tester
This is a Ford 17-Z-803 Tester.
It is the predecessor to the 18-Z-245 Coil Tester.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- Last Name: Hanlon
Re: Coil tester
I knew Bob would know.
- First Name: Tom
Re: Coil tester
Thanks for the info. As always Tom
- First Name: BOB
Re: Coil tester
I learned what I know about HCCTs from Ron Paterson
Be_Zero_Be
Be_Zero_Be
Re: Coil tester
I don't know how a Model T owner can be without one. I use mine frequently for myself and others.
- First Name: Thomas
- Last Name: Hicks
Re: Coil tester
The HCCT works well, but it is not the only girl in town. I have found the ECCT to be very accurate, and probably lower in cost.
Re: Coil tester
...and probably lower in cost
The ECCT is about half the usual cost of the HCCT, and so is the Strobo Spark.
- Last Name: Hanlon
Re: Coil tester
Along with my Allen HCCT, I have several different ECCTs, both 6V and 110V AC...
I prefer the HCCT, but run a distributor, so it rarely gets used.
- Last Name: Hanlon
Re: Coil tester
Here's a couple ECCTs, one DC and one is AC.
Sorry bout the glare, sunshine !
There's a homemade one that holds 4 coils, but the picture didn't come out.
- First Name: BOB
Re: Coil tester
Here are some interesting things that I discovered about the Jefferson Model 28 Coil Tester.
viewtopic.php?f=2&t=269&p=1586&hilit=jefferson#p1586
Be_Zero_Be
Be_Zero_Be
- Last Name: Hanlon
Re: Coil tester
Appears to be the one on the wall is a Jefferson.BE_ZERO_BE wrote: ↑Sat Feb 02, 2019 12:48 pmHere are some interesting things that I discovered about the Jefferson Model 28 Coil Tester.
Thanks Bob
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Re: Coil tester
I gave one of the Jefferson #28 testors to the Museum. I hope they still have it
- First Name: Douglas
- Last Name: Keppler
Re: Coil tester
Dave, with all due respect I believe the ECCT is the Electronic Cranked Coil Tester as designed and sold by Mike Kosser www.modeltecct.com
1924 Touring car
There's No Substitute for Proper Lubrication
- Last Name: Hanlon
Re: Coil tester
Pardon my ignorance, what should I call a non hand cranked tester.Doug Keppler wrote: ↑Sat Feb 02, 2019 8:09 pmDave, with all due respect I believe the ECCT is the Electronic Cranked Coil Tester as designed and sold by Mike Kosser www.modeltecct.com
No offense to Mike was intended.
Re: Coil tester
It's probably a buzz box coil tester which most likely only tests the primary and secondary coils to tell you if they are good
1924 Touring car
