Gasket replacement for carbide generator?
GJScholz
First Name: Gregory
Last Name: Scholz
Post by GJScholz » Sun Jan 06, 2019 8:29 pm
Hi,
I need to replace the gasket on the carbide generator.
What is the group's consensus on the process, materials, and method?
If you have any best bets, resources or success stories, I'd love to know.
BTW, I repaired my leaks with silver solder! Successfully, but not without trepidation.
Thanks for your advice.
Thank you,
Greg
Greg Scholz
4th Generation Caretaker
1914 Ford Touring
Survivor Class
http://personal.gregscholz.com/
Esko MN
KD0UYN ‘73
KeithG
First Name: Keith
Last Name: Gumbinger
Re: Gasket replacement for carbide generator?
Post by KeithG » Sun Jan 06, 2019 8:47 pm
I tried to find a new gasket for my carbide generator a few years ago with no luck. I tried all the vendors & no one ever carried them. I finally came to the conclusion that RTV would work. Lay it in the grove very carefully & try to keep it even and let it cure real well before putting the generator back together.
Hope this helps.
Keith
GJScholz
First Name: Gregory
Last Name: Scholz
Post by GJScholz » Mon Jan 07, 2019 10:55 am
Thanks Keith!
I'm not too steady in the hands, so I may need to investigate carving one out of a mouse mat or something.
Thank you,
Greg
Greg Scholz
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
namdc3
First Name: Nikolaus
Last Name: Martin
Post by namdc3 » Mon Jan 07, 2019 11:59 am
Greg, I cut mine out is a piece of Viton, probably from Amazon or McMaster-Carr. If your hands are unsteady, find two circular cans that right diameters and essentially trace them with a sharp exacto knife.
GJScholz
First Name: Gregory
Last Name: Scholz
Post by GJScholz » Mon Jan 07, 2019 12:46 pm
Thanks,
I'm going to order up some Viton rubber sheeting, and cut myself a new one. I'm supposing that the outer edge is pretty important, and as long as I leave it wide enough, the inner edge is not so important.
I'll let you know how it goes.
Thank you
Greg Scholz
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
