Hand Crank Mod
Thorlick
Topic author - Posts: 214
- First Name: Terry
- Last Name: Horlick
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
Hand Crank Mod
Rusty is ready and waiting for his engine so I am preparing to assemble and install same.
I once read of someone doing a hand crank mod and thought that might be fun someday. Well, today is the day and although he is getting his original engine back, he is also getting this radical modification. I will outline it here in case others want to do this or something similar.
After replacing the pan's worn out front bushing with a new steel bushing courtesy of Erik Barrett (who did all the engine machine work) I drilled a starting hole in the front. ... and enlarged the hole whilst also drilling and tapping the crank handle to 1/4-28. Here is the completed modification. Here is what it looks like with the crank being held in the erect position. (to be continued TH)
Thorlick
- First Name: Terry
Re: Hand Crank Mod
Here you see a close-up of the complete modification. My bolt was a broken 1/4" AN bolt from my junk pile. After threading the bolt and running it in so it is flush at the top side of the crank the bolt head will rest just above the outer surface of the bushing I need to grind about 1/8" off of this bolt to lower the head. Since this bolt is already drilled I will be putting a safety wire in there.
The crank in the erect position.
You can let the crank dangle like it normally does.
Or by pushing the handle inward you can crank your car normally.
Now you can see what I am doing. The N, R and S cars would leave their crank in an erect position, but the T saves on not drilling a notch and not inserting a bolt. The poor little T has it's crank hanging low, where it can ram into piles of snow or mud or just look flaccid. I want to see what Rusty would look like on Viagra!
Respectfully submitted, TH
doodlebugt
- First Name: Bruce
- Last Name: Csorba
- * REQUIRED* Type and Year of Model Ts owned: 1915 4 spring Rajo racer, 1917 C-cab van, 1925 Dalgety tourer
Re: Hand Crank Mod
Hi Terry,
It was "Fast Frank" with the proud crank.
I've often thought about it.
Bruce (still drooping)
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
17 C-cab van
25 "Dalgety" Tourer
Re: Hand Crank Mod
Frank in crank-up mode.
Seamus has this upright-crank accessory on his 1914.
Thorlick
- First Name: Terry
Re: Hand Crank Mod
Steve,
Does Seamus have the driving light on the front axle in case he runs out of carbide?
We have a stretch of state highway between Grass Valley and Auburn which is posted "Daylight Safety Section". Theoretically you must run headlights or risk being cited unless you are female with suggestive clothing. When I had "Toady" (my 1913 Mountain Wagon model T) I used to flaunt this law whenever driving that road because I didn't want to have to clean up the carbide mess for just 28 miles of driving.
I also am "very concerned" about a recent law which mandates you illuminate headlights whenever you "turn your wipers on". Since I use my intermittent mode on Rusty when it is raining (reach up and wipe the wiper across the windshield when needed) I don't turn the lights on each time I wipe the wiper. If I turn the lights on in the daytime I would soon have a dead battery (as a sexigenarian... cool sounding attribute I can use for four more years... it is mandated that I forget to turn the lights off). I feel exempt from this law since I don't ever "turn my wipers on" when I use them (possibly they require a younger more attractive driver to be "turned on").
Ok, back to treating the model T hand crank affected with E.D.
TH
TH
Thorlick
- First Name: Terry
Re: Hand Crank Mod
Steve, Seamus accessory is a bit hard to see. it is interesting indeed!
TH
TH
mcenhillk
- First Name: Kevin
- Last Name: McEnhill
Re: Hand Crank Mod
I just happened to stumble across this accessory on Lang's this morning.
https://www.modeltford.com/item/3664CH.aspx
Kevin
Kevin
Still looking for the 1,000 square foot house with the 12 car garage...
Re: Hand Crank Mod
Here's a later model stamped steel "OAKES" Krank-Loc on our '14 - I believe the early ones were cast.
Loftfield
- First Name: Thomas
- Last Name: Loftfield
Re: Hand Crank Mod
Thanks to Mr. Horlick for explaining the finer points of hand crank positioning. I now know why so many Model T's have that kinky leather jock strap, and the bells (balls?) suspended from the front axle on those cars that are more anatomically complete and correct.
Thorlick
- First Name: Terry
Re: Hand Crank Mod
Thomas, thanks. I used to hang an old model T magneto magnet below my differential with a bit of bailing wire. It was amazing how many folks accepted my explanation that it was to catch parts which had fallen off!
I took it off when I discovered that it slowed Rusty down whenever we crossed railroad tracks.
TH
TH
TonyB
- First Name: Tony
- Last Name: Bowker
Re: Hand Crank Mod
I have one on my 1909, I had never seen one previously so I thought it was special. Now I see they are being reproduced, in brass no less, mine is cast iron.
All my other Ts have a cup and leather strap
Tony Bowker
La Mesa, California
La Mesa, California
