Here are some pictures people might want to see from Sierra Vista.
Sorry it took so long, hard drive failure. luckily i had most of my picture on an external hard drive.
Sierra Vista Pictures
Topic author - Posts: 2
- Last Name: Held
Re: Sierra Vista Pictures
I'm still paying big time for a bad batch of gasoline I bought in Sierra Vista several years ago. So far I've had to remove the gas tank by lifting the body up to extract it, and flush the tank out and re-solder the gas tank flange. There is apparently still some residual crap in the system, but I've learned how to keep it running by refusing to give into the problem. Recently I've installed a modern filter in the system, and I hope that helps.
