Broken early style horn tubing brackets
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Fri Oct 18, 2019 3:08 pm
If anyone has one or more of these that have broken or otherwise performed poorly and are no longer wanted, I'd be interested in buying them.
These are the long style tubing brackets that mount to the outside of the body at the front seat.
PM me at rvmodelt AT netsync DOT net
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Re: Broken early style horn tubing brackets
Post by R.V.Anderson » Sun Oct 20, 2019 4:57 pm
TTT 1
Post by Original Smith » Sun Oct 20, 2019 9:23 pm
Gosh Randall, I can't believe you want to deal with that junk! Of course if you are going to modify it to look like what Ford actually used then you are forgiven!
