Electrical connectors
Daniel828
Topic author - Posts: 45
- First Name: Daniel
- Last Name: Brennan
- * REQUIRED* Type and Year of Model Ts owned: 1
Does anyone know if auto industry from the 1920s used any kind of connector or plug in any of the cars? I’d like to add a couple connectors into my headlight wiring harness. I bought a “lot” of model t parts from eBay and there was a wiring harness included but it was hacked up a little bit and the headlight wires are too short and I’d like to lengthen them
Dan
Dan
Re: Electrical connectors
My guess is that the Bakelite tubes with bullet connectors were first used in the thirties. That's what I'd use. They would be almost period correct.
Another choice would be to purchase a new loom. They are not that expensive.
George Mills
- Last Name: Mills
Dan,
When I put together an era correct turn/4-way/brake self-designed kit on my Hack and in keeping with my '20's technology theme cap for every part sourced, I eventually settled on something Ford issue even after looking at others for one of the needs. Rather than use a Model T head light connector for the two bulb tail-lights (it looked really clunky to me) I allowed myself to have in-line connectors for things like the lamps added at the rear and I actually wound up using stock Model A stuff from a vendor catalog! There are tiny bullet type connectors that come with female line connectors (meaning, you put a bullet on each end then click them into the double end female connector)
I was happy with it, all said and done...sorry, no pics, I'm not near the Hack.
FYI- The part numbers were A-14487 for the female, and A-14486 for the male. They were actually relatively cheap in the big scheme of things...lol
Daniel828
Original Smith I thought about that but I’m using a homemade depot hack body and the way I have my wiring harness routed, a new harnes would still be short
But thank you for suggestion
George. Thank you for part numbers , I’ll take a look at them. Sounds about what I’m looking for
Here are pictures of the parts #'s described above. These should be available at local automotive supply, hardware or home improvement stores. However , color may be an issue. If so use black shrink tubing
- Attachments
- A_14486.jpg (7.66 KiB) Viewed 6435 times
- A_14487.jpg (7.58 KiB) Viewed 6435 times
Daniel828
Yeah cool. I’ve seen those parts listed on some parts house websites. I don’t quite understand how they work. Does the metal bullet connector plug into tha back of a different one ? And they are installed inside the black covering?
Susanne
- First Name: Susanne
- Last Name: Rohner
There's a metal tube inside the black insulation that the bullets plug into on either side.
I am in agreement with Frank on this and his advice to use shrink tube to mask everything is right on...I almost duplicated his post until I reread it. With black shrink tubing and black wire-cloth, the connections will be nearly invisible.
I crimped mine and sleeved with heat shrink...this is how I handled rewiring my runabout's twin tail lights. Works great...looks great. Had I thought about them, Bullet connectors are probably a better choice.
Daniel828
Got it. I know what I’m going to do now. Thank you everyone
Pep C Strebeck
- First Name: Joseph
- Last Name: M
I have always used Rhode Island Wiring Service for supplies when I want to do a "non-traditional" application on vehicles/projects but have it blend into the background. They have some nice 1 into 1 bakelite bullet connectors that would probably be what you are looking for. I have used there supplies on the T's, Dodge Brothers, A's and the Farmall Cub. I used the 1 into 1 bakelite connectors for the headlights on the Cub, installed in-line for the headlight wires it makes removing the hood a lot easier. You can find then on-line at riwire.com I also agree with the shrink tubing, but some that I have found end up being "glossy" after installation, I always look for shrink tubing that ends up matte/dull.
I agree with shrink tubing. It's not original, but looks better than the plastic insulators that come with the terminals.
It comes in many colors and textures too.
Any connector is a possible source of failure. It is easy to extend wires by splicing the two ends together and soldering the joint. Heat shrink is your friend to insulate the joint. Sometimes I have even cut the existing wire shorter to make the joint where it cannot be seen.
