I replacing the rear tires on my 26 touring. It has wire wheels. And see that one seal leaked pretty bad so was going to replace both outer seals. But should I also do the inner seals?
Thanks Tom
Rear axle oil seals
AndyClary
- First Name: Andrew
- Last Name: Clary
Re: Rear axle oil seals
Yes, you need to do the inner seals also. Check the sleeves and bearings for wear since you can't deal an axle wallowing around in the tube.
Andy
Andy
