Old Photo - model T Bus
Topic author - Posts: 6895
These right-hand drive Buses caught my eye this morning. Apparently English.
- First Name: Dallas
- Last Name: Landers
Re: Old Photo - model T Bus
I would like to see them with the top up. Bet its not a one man top. Very cool. Thanks Rich!
I can tell you from putting my 11 passenger Bus top up, it takes two tall people and a third in the seats to get it up and down.
HPetrino
- First Name: Henry
- Last Name: Petrino
Thanks for the photos. I love seeing TT's in the various uses they are capable of.
In the upper photo you can't see the undercarriage at all. In the lower one it appears that there are no auxiliary brake rods (hard to tell with certainty). All that weight and only the transmission brake? Scary.
HornsRus
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
it has brakes, std 1 ton with frame extension with extry springs. that's what i see. charley
GEmering
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
What a wonderful vehicle.
I wonder what's under the hood?
It can't be 20 hp, can it?
Gene
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
HPetrino
- First Name: Henry
Gene,
I'm thinking the engines are just stock T engines/planetary transmissions. It's possible there's am auxiliary transmission in them. In any event, remember that the rear end (even the so-called high speed gear set) has a pretty low ratio. Speed in the day was not perceived the same way we see it in modern times. Maintaining 30 MPH was flying low. More likely those busses probably rarely saw anything over 20 MPH.
Charley,
I see what could be an auxiliary spring bracket in the lower photo, but I'm not so sure either bus has an extended chassis. They both look to me like stock they have a length TT chassis. Just my $0.02 worth.
Charley,
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
Jackson’s Faces was a photographic studio in Great Yarmouth, England.
Belle Coaches show a similar bus on their history page:
http://www.bellecoaches.co.uk/History
There is one of those buses (with a roof) at Ipswich Transport Museum, the chassis and front brakes look interesting.
HornsRus
- Last Name: Shaver
the frame ex starts at the firewall you can see the ford frame behind it. the ford frame stops at the rear axle.charley
Jem
- First Name: Jem
- Last Name: Bowkett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
There are 17 people in that first charabanc, at a conservative estimate that is 1 ton, without the heavy bodywork. Poor little Ford.
On the bus in the museum, I wonder what axle they've put under it and how the brakes are rigged.
Jem
- First Name: Jem
On the second chara, I don't think that's a frame extension you can see, it's the wooden bearers for the body, I think it's a standard TT.
HornsRus
- Last Name: Shaver
yes i see the wood beem now, but from the gas cans back i see steel that the springs are bolted to and runs all the way to the back. charley
tom_strickling
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Someone brought one of these to display when the MTFCI Summer tour was in North Carolina. It was HUGE!!!
Often those bodies were easily removed. The trucks were trucks during the week, and the charabanc was fitted for weekend tourist work. I have some photos of other makes set up for this purpose.
