Wheel adapters
Dennis_Brown
Topic author - Posts: 277
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Wheel adapters
I know it is covered before, but who makes a 6 hole wood hub adapter to go to a 5 hole 5 1/2 inch pattern to fit Model A wheels? Any Idea what they are made of or what they cost and any pictures if you have them. I would like to know what they look like . Thanks
Re: Wheel adapters
They are listed in several of the catalogs, Lang's, Snyder's and maybe Chaffin's etc. Personally I am not impressed on any of the designs sold. None of them are made with the understanding on HOW the Model A wheel is mounted that I can see. The Model A wheel was designed for 3 points of contact, none of which are the lug bolt holes. In fact, the properly mounted A wheel, the lug bolt holes would not even come in contact with the hub/brake drum.
steve plowman
- Last Name: Plowman
- * REQUIRED* Type and Year of Model Ts owned: 1926 cut down tourer
Re: Wheel adapters
I have looked at various ways to fit 5 stud wire wheels to my 6 bolt wood wheel hubs but getting the wheel centre to rest on the hub nose is the bit that I haven't worked out successfully. I always come to the conclusion that it would be better to make new 6 lug wheel centres and lace them up to suitable rims, which seems like re-inventing the wheel like McLaren Wheels have done .. beyond my purse, but I would love a set.Mark Gregush wrote: ↑Sun Nov 03, 2019 1:23 amThey are listed in several of the catalogs, Lang's, Snyder's and maybe Chaffin's etc. Personally I am not impressed on any of the designs sold. None of them are made with the understanding on HOW the Model A wheel is mounted that I can see. The Model A wheel was designed for 3 points of contact, none of which are the lug bolt holes. In fact, the properly mounted A wheel, the lug bolt holes would not even come in contact with the hub/brake drum.
I have also looked at just using a simple adapter plate and running Austin Seven (late model) 3 lug wheels which come in useful sizes for available vintage tyres here in the UK. Fine for a lightweight speedster but maybe not so good for a full bodied car.
[image]http://mclarenmfg.com/pics/mclarenwheels.jpg[/image]
1926 T Touring cut down with tray back "The Gin Runner"
1926 TwinT straight 8 project
1928 Indian Chout
1940 Indian 640 Stroker
1928 Indian Chout
