Proper torque for manifolds on 1920 roadster?
Jed
First Name: Jed
Last Name: Welsh
* REQUIRED* Type and Year of Model Ts owned: 1920 Roadster pick-up
Post by Jed » Tue Oct 29, 2019 3:22 pm
What is the Proper torque for manifolds on 1920 roadster?
Last Name: Humble
Board Member Since: 2006
Re: Proper torque for manifolds on 1920 roadster?
Post by Humblej » Tue Oct 29, 2019 4:11 pm
Same as a coupe or touring, hand tight with a short handled ratchet wrench. For head bolts torque matters, for most other bolts no.
Post by DanTreace » Tue Oct 29, 2019 4:15 pm
Only a 3/8” thread, use a 7” long sm. handle ratchet , you’re only compressing the soft gland gaskets, if you have to use a fancy torque wrench, max of 15 lb/ft or so.
Jed
First Name: Jed
Last Name: Welsh
Post by Jed » Fri Nov 01, 2019 8:33 pm
I use what I got. I happen to have one of those fancy torque wrenches from my young days.
Thanks for the help, Jed
Post by Steve Jelf » Fri Nov 01, 2019 10:42 pm
You tighten a nut until just before it strips.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Mon Nov 04, 2019 5:29 am
Or, tighten it up until it strips, then back off half of a turn. :roll: I know, it doesn't make sense, but that's one of the expressions that I grew up with from back in the early '50's, sort of like "jack up the radiator cap and roll another car under it", to describe a badly worn out (junk vehicle) vehicle. :lol: Dave
1925 mostly original coupe.
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Mon Nov 04, 2019 11:51 pm
The one I remember was " Tighten till failure then 1/4 turn" seems about right. :) . Jim
