Mike Kosser's new tool
Topic author - Posts: 2916
- Last Name: Hjortnaes
Did anyone take a picture? Did anyone like it? I would like to know what it is. Thank you
- First Name: Gene
- Last Name: Carrothers
Re: Mike Kosser's new tool
If Mike has made a new anything I want to know about it so if anyone knows what it is Please let us know!
1912 Torpedo Roadster
- Last Name: Bartsch
The tool Mike displayed at Hershey is a version of the coil points adjusting 'hammer' you see in the ford service manuals. It is laser or plasma cut from steel plate. There may be other 'tools' and there is ongoing controversy if you read earlier posts. I have no affiliation with Mike K or any products offered. jb
- Last Name: Jablonski
Dave: I have a drawing of the tool, cannot post any pictures since the neighbor's third grader isn't home yet. Nice combination in one tool to adjust coil top hardware. Thanks again Mike. This tool eliminates two problems.... The larger squared handle with covering prevents turning in use, and prevents loss of a second tool.
- First Name: Thomas
- Last Name: Petry
Pictures and dimensions would help those of us who might desire to make one of our own.
https://www.modeltford.com/item/5008AH.aspx
Without seeing it only thing I could think of is, a slot for adjusting the cushion spring was added at end of handle to make it different from what is currently sold. A wide slot might do both old and new style points.
https://www.modeltford.com/item/5008CST.aspx
I bet for many of us a small hammer, screw driver and the cushion spring tool works just fine.
- First Name: Mike
- Last Name: Kossor
Here is a link showing the tool. I believe the rules permit me to share a link. I received over 40 signatures on the petition to revoke the Vendor Discussion rule at Hershey.
The rule presently prohibits vendors from posting photos, detailed descriptions or discussions of their creations here on the forum. Hopefully 40 MTFCA member signatures will be sufficient to convey the message there are many members who would like the rule revoked. That's about 10 times the number who believe the rule improves the forum that I am aware of.
https://www.facebook.com/groups/Fordmod ... /?sfnsn=mo
Folks with a plasma cutter, water jet or LASER cutter can make their own but will have to email me for the dimensions because I am prohibited from sharing a dimensional drawing by the rule. Others will be pleased to know it will soon be readily available.
- First Name: Anthonie
- Last Name: Boer
I made this off a [nice] knife for adjusting thecushion spring .
- First Name: Don
- Last Name: Ellis
Here’s mine, with a custom grip!
Nice nautical thing you got going there !
Now available to order. Sent in my order today.
