Sideways photos again
Post by Steve Jelf » Wed Nov 13, 2019 11:28 am
I often see photos posted sideways like this one of Chady Attaberry and Ed Emerson. If you click on it, you'll see it correctly oriented. But I've found that I can make the thumbnail appear correctly when I post it. The sideways problem invariably affects photos in a vertical format. So before I post a vertical shot I rotate it 90º left or right (it doesn't matter which), and then rotate it back to the correct orientation. Then when I post the picture it appears correctly.
Re: Sideways photos again
Post by RajoRacer » Wed Nov 13, 2019 11:31 am
Was still sideways when I clicked on the original ?
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Nov 13, 2019 11:43 am
Before posting I have to put all pictures in preview, although they are correctly oriented, have to rotate them 360 degrees then they come out right. Sent Jeff an email, has him a little baffled too. Damn Cyber Pixies!
Hank
Post by Mark Gregush » Wed Nov 13, 2019 11:58 am
When I clicked on ether picture, they both were orientated correctly.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Wed Nov 13, 2019 12:39 pm
If I take a photo horizontal with my phone it is right side up on my post. If I take it vertical with my phone its sideways on post. Go figure!
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Nov 13, 2019 1:24 pm
Steve, when I click on your photos, the sideways photo stay sideways when using Internet Explorer. If I use Google Chrome, they rotate to the correct orientation.
brucesp
First Name: Bruce
Last Name: Spainhower
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1926 Fordor
Post by brucesp » Wed Nov 13, 2019 4:43 pm
The issue with sideways photos is that all digital photos are taken horizontal, i.e. long dimension by short dimension; not the other way around. Embedded in every JPG image is a set of information about the photo: date, time, shutter speed, aperture, and a whole lot more including which orientation the camera was held at. It's called the EXIF information.
Most modern software (such as Windows 10) reads this EXIF info and rotates the image on the fly for viewing only, but it doesn't actually rotate the photo underneath. It drives me nuts, because I have yet to find a way to turn off this "feature" to see the photo the way it was originally taken. This is a real problem because when you place a photo into a forum post, it's the original, not the temporary viewing version. That results in things like Hank Lee posting, "What is going on with the picture imports? They are vertical when I start!" Actually, Hank, they're not vertical when you start, but your computer (or phone) hides that fact from you. The forum software is doing it right.
So, this brings me to the fix I have found. I use a free program called IrfanView, available here. It's a very capable image convertor that not only takes care of the rotation problem, but also deals with resizing, and all sorts of other image adjustments. Any time a photo is going to a destination that doesn't have the auto-rotate "feature", it's a simple matter to select the photo in IrfanView, press <Shift><J>, and choose "Auto-rotate according to EXIF orientation." You can also do this with all photos in a folder at once.
It's pretty easy to get used to passing photos through this program on the way to the forum. A final thought – when posting a message, use the "Preview" button before hitting "Submit". That'll reveal which photos need rotating.
PDGx
First Name: Paul
Last Name: Grohsmeyer
* REQUIRED* Type and Year of Model Ts owned: ‘17 TT Holmes Wrecker
Post by PDGx » Thu Nov 14, 2019 4:21 pm
The software used for this forum (and another that I frequent) will post (preview) pictures in the portrait mode by default. Rotating vertical pics twice as stated above will orient vertical pics properly in the preview screen.
For some reason however, the software will orient them correctly if you click on them.
Other forums using this same forum template are also baffled by this.
