AC Brakes and Hassler Shocks
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Fri Nov 15, 2019 3:39 pm
Will Larry Sidmore's AC brake set up fit with Hassler shocks? Correct me if I'm wrong, but I don't think Rocky Mountain brakes and Hassler shocks work together. This is for a small drum.
Last Name: Gregush
Re: AC Brakes and Hassler Shocks
Post by Mark Gregush » Fri Nov 15, 2019 8:48 pm
While mine were original small drum AC's, the mounting is the same. I had the bee hive Hasslers on mine with no issue.
Wilbur
First Name: Wilbur
Last Name: Swearingin
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout 1923 Coupe 1924 Tudor 1926 Pickup
Post by Wilbur » Wed Nov 20, 2019 5:26 pm
I have pancake Hasslers and AC brakes. Work OK
