Obscure speedster trivia 2...?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Dec 07, 2019 10:15 pm
Since the last go around was solved in just 30 minutes...
Anybody recognize this gear set?
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Re: Obscure speedster trivia 2...?
Post by Steve Hughes » Sat Dec 07, 2019 10:37 pm
Distributor gears.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Sat Dec 07, 2019 11:57 pm
Atwater Kent ??
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Sun Dec 08, 2019 12:08 am
I agree with distributor gears, the lower one on camshaft and the other on the dizzy.
Tony Bowker
La Mesa, California
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Dec 08, 2019 12:19 am
Distributor gears.
Getting warmer... but which one?
Atwater Kent ??
Not this one
Last Name: Gregush
Post by Mark Gregush » Sun Dec 08, 2019 2:39 am
Delco? With all the different distributors made for the Model T this could be a real challenge. It's not Bosch.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Dec 08, 2019 1:09 pm
Not Delco... and it’s supposed to be a challenge! ;)
While not Bosch either... this accessory did come outfitted with a Bosch distributor as an option...?
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Sun Dec 08, 2019 3:47 pm
Probably drive gears for a triple plate.
Andy
Last Name: Gregush
Post by Mark Gregush » Sun Dec 08, 2019 4:41 pm
Texas T distributor
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Dec 08, 2019 4:54 pm
Andy
You got it!!
Here are a couple original Tri-Unit ads showing the timer elevator, and the Bosch option
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Dec 08, 2019 6:53 pm
Here is a pic of the inner workings...
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Sun Dec 08, 2019 7:36 pm
Now that is a 🍑!!! If you're into accessorie kind of things!
