Hardwood floor boards - “C” Cab
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Post by Nunsio1 » Fri Dec 06, 2019 2:22 pm
I have hardwood floor boards for my 24 C cab on back order with Langs for almost 2 years. All ways have had good service and parts from them but wondering if there is a different option, or someone that has prints so I can make them myself, when I need them in spring. Thanks for any help.
Re: Hardwood floor boards - “C” Cab
Post by Scott_Conger » Fri Dec 06, 2019 7:28 pm
Here is an outstanding thread regarding floorboards. Most importantly, numerous people show the edge reinforcement that is completely lacking in any reproduction that I have seen. Not your exact vehicle, but if you follow the methodology found here, you will have a hard time finding someone to pick your truck apart (though there seems to be a never ending supply of critics, if given the chance).
In any event, the boards are 5/8" thick and the underside cleats are box nails nailed from the top, through the cleats and then clinched over. Frankly, the rest is cut to fit, in your instance
http://www.mtfca.com/discus/messages/70 ... 1504726702
Nunsio1
Post by Nunsio1 » Sat Dec 07, 2019 8:31 am
Scott:Thanks for the information-very helpful.
John..Oscoda Michigan
