2 wrench valve lifters
Dennis_Brown
Topic author - Posts: 269
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
What keeps 2 wrench valve lifters from backing off. I can see that with a lock nut they are more apt to stay in adjustment.
Re: 2 wrench valve lifters
Dennis,
"What keeps 2 wrench valve lifters from backing off?"
To answer your question: Not much.
Have had a few friends with those, and the adjustments backed off. Yes, there is a locking method, but in what I've seen, it's not as guaranteed as the lock nut. I've never seen one of the screws as pictured above. I have seen a style that uses a locking type thread form, (the trade name for it escapes right now).
Roar_Sand
- First Name: Roar
- Last Name: Sand
Could it be "Root interference lock thread", as used on the Mopar "leaning tower of power"?
Roar,
Yes, that's what it is. Trade name is Spiralock. There's probably others too. https://www.stanleyengineeredfastening. ... /spiralock
Kohnke Rebabbitting
- First Name: Herman
- Last Name: Kohnke
- * REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
The lifter bolt shown in the picture, the slot will close up, or one side will brake off, NO FIX.
The best are BOBs, In IL.
They are made the way they should be. The bolts, nuts, and lifter body, laugh at a file.
As always, any brand of lifter, should be butt. None are perfect.
That is why some people say adjustable lifters loosen up, because the high spots wear off, and then they are loose.
Here are some pictures.
Herm
Herm
Kohnke Rebabbitting
- Last Name: Kohnke
One more thing, you do NOT need 3 Wrenches, on lifters, with a lock nut.
Hertm.
Hertm.
Kohnke Rebabbitting
- Last Name: Kohnke
Correct. And, you do NOT need to cut down your tappet guides in the engine block in order to adjust your tappets.Kohnke Rebabbitting wrote: ↑Sun Nov 03, 2019 3:49 pmOne more thing, you do NOT need 3 Wrenches, on lifters, with a lock nut.
Hertm.
Ok so how do you keep the lifter from turning when you snug down the lock nut without using 3 wrenches? I have yet to see lifters that when down you could hold it with a wrench, maybe the flats were just peeking over the top. No you don't have to trim the lifter bosses, even if you know the secret to the threads per inch thing you still have to go thru several cycles to set them. But just taking a little off the top clears the way for adjusting without cranking the motor over to drop, check, turn again, adjust, drop to check etc.
Kohnke Rebabbitting
- Last Name: Kohnke
Mark, I haven't seen your post , until today, I will let you know how we do it, tonight if I can. Pouring a 1922 Olds. today, just got done with a 1903 Curved Dash Olds, a few days ago.
Herm.
Herm.
Kohnke Rebabbitting
- Last Name: Kohnke
Ok, this is the way we do it.Mark Gregush wrote: ↑Wed Nov 06, 2019 11:34 pmOk so how do you keep the lifter from turning when you snug down the lock nut without using 3 wrenches? I have yet to see lifters that when down you could hold it with a wrench, maybe the flats were just peeking over the top. No you don't have to trim the lifter bosses, even if you know the secret to the threads per inch thing you still have to go thru several cycles to set them. But just taking a little off the top clears the way for adjusting without cranking the motor over to drop, check, turn again, adjust, drop to check etc.
1. Butt both ends.
2. The lifters are Bob's, the only good ones. Take all the bolts out, and nuts off, and either blast, or wire brush the threads. Make sure the nuts do not move the bolt when installed, that is, rotating freely, and assemble bolts.
3. Put a heavy grease on the lifter body, none on the lifter foot, and install the lifters.
4. We set the valves, with out the valve springs.
5. We use a light spring under the valve to keep it out of the way. It came in a hand lapper, one time.
6. Push the valve down, take the other hand and take a reading with the feeler gauge, and let the valve spring, out of the way.
7. Grab the top of the bolt and place the wrench on the body of the lifter, and push lightly inward, with the other hand, loosen the lock nut, and you should be able to adjust the bolt, and nut by hand, and then snug, lock nut.
8. All the pictures I can find now are of valves on a Model A, which would be the same process as a T, and B Ford.
9. I always point the cam toes downward.
Herm.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Anyone have a link to Bob’s lifters?
Kohnke Rebabbitting
- Last Name: Kohnke
Bob's Antique Auto Parts, Quincy, Il.
Herm
Herm
KeithG
- First Name: Keith
- Last Name: Gumbinger
With all due respect, Bob's Antique Auto Supply is located in Loves Park, IL, not in Quincy, IL.
Keith
Keith
dmdeaton
- First Name: Danny
- Last Name: Deaton
So the lifters he sells are not the same as Snyder's ? They carry the 2 wrench lifters also.
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
We make the lifters right here in Loves park, we just bought some machinery to start making them in house, hopefully six weeks they will be back on the shelf, currently out of stock, Bob
Kohnke Rebabbitting
- Last Name: Kohnke
dmdeaton
- First Name: Danny
- Last Name: Deaton
Bob said he is not making the the 2 wrench anymore
Kohnke Rebabbitting
- Last Name: Kohnke
