Timing issue
Unprr
Last Name: Schmidt
* REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Timing issue
Post by Unprr » Sat Dec 14, 2019 7:21 pm
Dear fellow Model T experts, I need some advice.
After putting in new pistons and valves, I’m having a hard time starting my car. I pulled the plugs and hand turn the motor until the first plug fires. It seem that the piston has traveled to far down at this point.
What am I doing wrong?
I have a mark at TDC, on the crank and it appears to be past the 15.5 degree point.
I have an Anderson timer and it appears to be in working condition.
I adjusted the timing rod to measure 2.5 inches from the rod to the bolt holding the timer on.
When it does start, it has very little power.
George
Last Name: Humble
Board Member Since: 2006
Re: Timing issue
Post by Humblej » Sat Dec 14, 2019 7:33 pm
George, the 2.5 measurement is only for the ford timer. Crank the engine to place the piston at tdc, or just past tdc, then adjust your timer rod by the plug sparking at full retarded spark lever position.
Last Name: Strange
Re: Timing issue
Post by CudaMan » Sat Dec 14, 2019 8:06 pm
