Valve timing
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Valve timing
Post by Dennis_Brown » Mon Jan 06, 2020 10:53 pm
Does it do any good to check valve timing with the head on other than to see if anything has changed? Unless one has adjustable lifters, no adjustments could be made. Just running things thru my mind.
