Just got a full rubber replacement kit for front windshield for 1927 Touring.
Is there any wise information or tricks to the replacement?
1927 Touring-replace front windshield rubber
BMonoModelTFord
Topic author - Posts: 7
- First Name: Bill
- Last Name: Monahan
- * REQUIRED* Type and Year of Model Ts owned: 1927 Model T
- Last Name: Strange
- Board Member Since: 2013
Re: 1927 Touring-replace front windshield rubber
On my 1924, the gasket between the cowl and the base of the lower windshield frame kept slipping out of place during installation, so I taped it down in a few strategic places with blue masking tape first. Once the windshield frame was in place, I was able to pull the masking tape out, leaving the gasket.
On the side seals for the upper windshield frame, I used a few dabs of black silicone sealant to help retain the seals in their slots. I let the silicone harden completely before putting any pressure on the seals.
BMonoModelTFord
- First Name: Bill
Thank you, I like the idea of the tape, great idea
EricMac
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 26 Touring (2006 Stynoski), 27 Fordor, '92 Stynoski, 'owner emeritus
When I restored my 26 Touring I also used black silicone to hold the gaskets in place. Don't worry, the windshield will continue to leak like yoy would expect!
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor
1926 Depot Hack project
1927 Fordor
BMonoModelTFord
- First Name: Bill
Thanks Eric
Do I need to remove the glass or is it possible to slide along track on lower and upper glass
