Wood Blocks AND a Belly Band?
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sun Jan 26, 2020 12:40 pm
My parts chassis came with an accessory belly band (engine support) that I’m going to swap over to my car.
I also have some new wood blocks for the engine pan ears. They were absent from my car when I bought it.
I’m wondering if I need both the blocks and the belly band.
1924 Touring
Last Name: Tannehill
Board Member Since: 2002
Re: Wood Blocks AND a Belly Band?
Post by JTT3 » Sun Jan 26, 2020 1:08 pm
Don I’ve done both, can’t hurt imho.
Post by RajoRacer » Sun Jan 26, 2020 1:27 pm
"Belly Bands" are just an inexpensive insurance policy IF one of the c.c. arms happens to come from together !
Post by Scott_Conger » Sun Jan 26, 2020 1:44 pm
Double thumbs up to Steve's comment
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sun Jan 26, 2020 2:07 pm
Thanks for all the input. I’ll be I installing both.
1924 Touring
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sun Jan 26, 2020 2:22 pm
The wooden blocks take the vibration out of the chassis, less chance of cracking pan arms with them in.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Sun Jan 26, 2020 5:02 pm
Ford warned about about using the side blocks in Trucks, that the frame twisting broke crankcase arms, and pan twisting from holding the arms to rigid.
So, I have never used them on cars since I was in my teens.
Don't believe it! Take your floor boards out, and install the side blocks and bolts, the way they should be. Take it, still without floor boards, on a little drive over NO more then what you think you would ever encounter on a trip, or drive. At this time, the wood block holds the arm from flexing. All the flex now is about 1/8th, to 1/2 inch from the pan, where most break. The arm now, can not take any of the relief. All so, rev. the engine a little, and watch both sides, to see what the motor and pan do, compared to the arms.
Now, take out the blocks, and bolts, and test it again. You will find the flex is spread out over the whole arm. We use just a 3/8's bolt, stuck, bottom up with a new lock washer, and 3/8's nut, NO key.
Even normal driving, when you crack that throttle, it moves the motor and Pan, around.
