Radiator prices
Philip
Topic author - Posts: 239
- First Name: Philip
- Last Name: Thompson
Radiator prices
Why is a radiator for an old Ford tractor 150.00 and a t radiator 900
tdump
- First Name: Mack
- Last Name: Cole
Re: Radiator prices
THe chinese make the ford tractor radiator
- Last Name: Humble
Re: Radiator prices
Cost of the materials, labor, and overhead for the quantity made and sold.
DickC
- First Name: Dick
- Last Name: Cruickshank
Re: Radiator prices
Dear Humblej: are you assuming domestic brass radiators are superior quality--like Brass Works?
Re: Radiator prices
The simple, brief answer is supply & demand.
You didn't ask, but I'll opine anyway.
For a brass era car, if the tank and attachments are fixable/usable I would get a recore. I did that because it preserves the original appearance and saves a few hundred dollars. I've also seen a few forum posts about new brass radiators breaking. I don't know how many have had that problem.
For a black era car I bit the financial bullet and bought a new Berg's because it will do its job and I don't have to worry about it. If I drive the car for ten years that Berg's cost per year is more than worthwhile to me. If I drive it longer than that, even better.
RustyFords
- First Name: Don
- Last Name: Allen
Re: Radiator prices
Ditto to Steve’s comments.
And...I also bought a new Berg’s unit fit my black car. It’s been nice to be able to drive my car in all weather having total confidence in it.
1924 Touring
- First Name: Keith
- Last Name: Townsend
Re: Radiator prices
oops. Hit a wrong button...
- Last Name: Juhl
Re: Radiator prices
I can't give a comparison between Brassworks and Bergs, but I bought a flat tube Bergs for my 1917 and so far so good. The car runs cool, never getting near to overheating, even on Indiana's covered bridge tour with daytime temps in the 90's. I have a Motometer Junior and the thermometer never rose into the circle.
A friend took delivery of my radiator at Hershey 2018 so I saved on shipping. Otherwise, one factor to consider is whether you live closest to the right or left coast.
- First Name: Keith
Re: Radiator prices
I was curious about the construction of a Berg radiator, so I looked at the Berg's site and Brassworks site and found a surprise!
For a flat tube 1917-1923 "low" radiator...
$875 Berg's http://www.bergsradiator.com/modelt.html
$825 Brassworks http://www.thebrassworks.net/shop/Repro ... _info.html
Yep, you read that correctly. The Berg radiator is more expensive than Brassworks radiator. The only "bargain" (aka cheaper) radiator that Berg's has is the 1917-1923 round tube radiator. At $900, it is $25 less than Brassworks.
There was a time that the Berg radiator was the "economy" version. You paid less for a product that was not an "authentic" reproduction. The construction of the Berg core is nothing like an original Model T core and visually there is a significant difference.
If you go the re-core route to "preserve the original appearance" you are going to have to get the core from Brassworks. Brassworks does not have a price list for a core only, so you would have to e-mail them for a quote. Then you would have to find a competent radiator shop that willing and able to work with your old brass.
I'm not in the market for one, and don't have a dog in the fight, but just wanted to share the facts I found online.
Keith
Keith
Re: Radiator prices
I didn't ask where my core came from, so that may be true. Or maybe it's true for round tubes. My car being strictly for go and not for show, I went with flat tubes. So it looks pretty much original until you get close enough to see what kind of tubes it has in it. In any case, the recore saved me a few Benjamins. The shop that did Rob's Model K did it for me.
modeltmick
- First Name: Michael
- Last Name: Seibert
- * REQUIRED* Type and Year of Model Ts owned: 23 tour
Re: Radiator prices
I purchased A Brassworks radiator for my 1923 touring car 19 years ago and it has been trouble free !
Re: Radiator prices
I bought a new Bergs radiator for my 24 Coupe after trying to repair or buy good looking originals that didn’t cool. It’s a good feeling to know you wont have a boil over when driving your car. Bergs black radiators are really similar to the Wards radiators that were popular in the T era and after.
Flat tube radiators are the way to go if you want to really drive your T and not worrying about authenticity at a car show. The average folks who are watching you in a parade or seeing T’s go by wouldn’t know the difference in a flat or round tube radiator and could care less.
Mark Osterman
- Last Name: Osterman
Re: Radiator prices
I bought a new Berg low radiator for my ‘23 runabout in 2017. Unfortunately it didn’t fit the original radiator shell correctly around the filler neck. So, I sent it back. When it arrived again it was spot on .. but got damaged in shipping separating where the inlet casting is riveted. Bergs paid for the local shop to solder the slight gap. Been driving around 100 miles a week in the non salt weather here in Rochester with no problems.
I did have one glitch. I had wired a vintage Rochester Auto Club badge in the lower front and after about three years I saw some seepage on the bottom tank. I removed the badge and poured some stop leak and haven’t had any more problems. A great radiator.
- Last Name: Hjortnaes
Re: Radiator prices
If you are concerned about $50 on an $850 radiator, you have a problem.
tdump
- First Name: Mack
- Last Name: Cole
Re: Radiator prices
If a extra 50 bucks is not a problem for you ,you are a blessed man.
No real reason for a T radiator to be that much higher than a tractor or other car radiator.
