Ford Piquette Plant, 1905
For all the models before the Model T
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Mon Feb 17, 2025 12:35 pm
Colorized photo of the Ford Piquette plant, probably in 1905. The grounds are still quite undeveloped with the 1/4 mile test track still in use.
On the right three men are testing a Model B (front engine crank is visible), with several cars near the center of the plant, apparently with bodies.
Rob
First Name: Rob
Last Name: Heyen
Re: Ford Piquette Plant, 1905
Post by Rob » Mon Feb 17, 2025 12:53 pm
The reverse side view of Piquette from a 1905 sales catalog. The track is seen with testing cars on the far right:
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Wed Mar 12, 2025 4:56 pm
Thank you! A VERY interesting post! I never knew a test track existed a the plant side on Piquette!
I know the powerhouse is long gone. Does anyone know what kind of engine and generator they had installed in it? Was it an Edison DC installation?
