Commutator contacts
For all the models before the Model T
JvanMaanen
First Name: Jim
Last Name: Van Maanen
* REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
Commutator contacts
Post by JvanMaanen » Wed Mar 25, 2026 6:49 pm
Was working on timing my SR prior to starting and found a flaky commutator contact. Does anyone know of a source for contacts and parts. I thought I might as well rebuild the commutator while I had the axel moved back and the engine and transmission separated. Model T parts would work with a little modification but didn't see anything in the catalogs. I know that Glenn Rand was making some replacements, but I haven't contacted Glenn for 10 years and no longer have his information or know if h still is making parts.
thanks Jim
paul schaefer
First Name: Paul
Last Name: Schaefer
* REQUIRED* Type and Year of Model Ts owned: 1908 S roadster, 1914 Touring,1925 touring, 1926 Truck, 1926 roadster PU, 1926 Coup
Re: Commutator contacts
Post by paul schaefer » Wed Mar 25, 2026 9:56 pm
Glenn is still working. Just a bit slower these days. I will share his contact with you just send me a
PM and I will send it to you.
