Was working on timing my SR prior to starting and found a flaky commutator contact. Does anyone know of a source for contacts and parts. I thought I might as well rebuild the commutator while I had the axel moved back and the engine and transmission separated. Model T parts would work with a little modification but didn't see anything in the catalogs. I know that Glenn Rand was making some replacements, but I haven't contacted Glenn for 10 years and no longer have his information or know if h still is making parts.
thanks Jim
Commutator contacts
JvanMaanen
Topic author - Posts: 200
- First Name: Jim
- Last Name: Van Maanen
- * REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
paul schaefer
- First Name: Paul
- Last Name: Schaefer
- * REQUIRED* Type and Year of Model Ts owned: 1908 S roadster, 1914 Touring,1925 touring, 1926 Truck, 1926 roadster PU, 1926 Coup
Re: Commutator contacts
Glenn is still working. Just a bit slower these days. I will share his contact with you just send me a
PM and I will send it to you.
