FS 1917 T Coupelet - Sold - Updated
Dliepelt
First Name: David
Last Name: Liepelt
* REQUIRED* Type and Year of Model Ts owned: 06 N, 07 R, 08 SR, 13 Delivery, 15 Touring, 26 Speedster
Post by Dliepelt » Tue Nov 08, 2022 7:11 pm
1917 T Coupelet, convertible top version with oval quarter windows. Older restoration but very presentable. Wire wheels and Ruxtell axle. Hasnt been on the road in many years. An unusual chance to own a very rare and desirable T. Link to photo album with many photos.
https://photos.app.goo.gl/viuVQ3K1As5zYdqU8
Car is in Binghamton, NY
Asking $18,500 or respectful offer. Make an offer!
Call Rob: 6035204447
struble.rob@gmail.com
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Re: FS 1917 T Coupelet
Post by Jim, Sr. » Tue Nov 08, 2022 11:02 pm
Here is how it would have looked in the Ford showroom.
1922 Coupe , 1926 Touring
Poppie
First Name: Neil
Last Name: Martin
* REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
Post by Poppie » Tue Nov 08, 2022 11:33 pm
David, Email sent, Thanks Admin....n
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Wed Nov 09, 2022 11:29 am
Good looking wheels, any idea who the manufacture is?
Post by speedytinc » Wed Nov 09, 2022 11:35 am
Hayes.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Nov 09, 2022 2:44 pm
Jim Sr’s picture may also be good documentation of how much oil a new T generally leaked. Just the fact that someone in a dealership left that pan under the car without wiping it clean is a good indication that sort of leakage was probably considered quite normal.
Tadpole
First Name: Tad
Last Name: Glahn
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Post by Tadpole » Wed Nov 09, 2022 2:57 pm
Leaky oil keeps the engine clean 'cause of all the oil you gotta add! I feel sorry for the poor guys that actually have to drain and change their oil...
Sarikatime
Last Name: Seress
Post by Sarikatime » Thu Nov 10, 2022 8:31 am
Adam, that amount of oil leaking from the T may have been normal those days when the driveway and the garage floor was dirt but not when you have a long concrete driveway and a nice clean garage. The wife is ready to kill me every time I move the T due to all the oil puddles. This is a brand new rebuild and the rebuilder didn’t give a damn and couldn’t care and outright refused to fix the huge amount of oil puddles problem every time the car was parked even for just a minute. Frank
Post by TXGOAT2 » Thu Nov 10, 2022 9:57 am
They all leak some, but a T in good shape ought not to leak a lot. Mine leaks very little. After driving 30-40 miles, it will drip a few drops at the front of the engine and a few at the rear. Once in a while, a dime size blob of grease will drop from the ball joint. It drips some oil right after oiling the chassis. It does make a mess over time on the floor where it is regularly parked. No puddles, but the drips accumulate over time such that I put cheap cat litter under the engine area. I use 5W30 or 10W30 synthetic oil and red # 2 grease. I oil the chassis and springs regularly, which adds to the drips. I'm compelled to run several miles on dusty dirt roads every trip, which doesn't help in keeping the car clean. It does not accumulate oil on the back of the body. Most oiliness under the car is in the flywheel housing area and around lube points. I routinely drive this car over 40 MPH. Driving slower would probably reduce oil leakage. Adding a road draft pipe to the oil filler would probably reduce oil escaping as mist. A positive crankcase vent setup would probably greatly reeduce oil leakage.
CraneJon
First Name: jon
Last Name: crane
* REQUIRED* Type and Year of Model Ts owned: 1925 T pickup, 1928 A, 1931 A
Re: FS 1917 T Coupelet Leakingoil
Post by CraneJon » Thu Nov 10, 2022 4:03 pm
At the FORD headquarters during the FORD Motor Company centennial they had a 1/4 mile curved demonstration track to give visitors a ride in a Model T. T's went around the fresh asphalt track for 10 hours a day for four days. Brother, that pavement was slick with oil! I was most impressed. They all leak if they have oil in them.
Jon
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Thu Nov 10, 2022 7:38 pm
I have a long concrete driveway and I run along and spray brake cleaner on oil drops after I take my T for a drive. It’s just one of those things.
Post by TXGOAT2 » Fri Nov 11, 2022 9:03 am
I guess I'm lucky. Mine does not leave puddles and it does not leak more than a few drops, if any, while sitting with the motor running while I open the gate or barn door. It certainly does not leave a trail of oil down the (dirt) driveway or when driven into the barn. (Concrete apron and floor) I keep the oil level as close to halfway between the upper and lower cocks as I can. I also have aluminum pistons and modern type rings. Leaky rings will assure plenty of oil escaping, besides any oil burned. Loose bearings will add to the amount of oil leaking and escaping as mist.
Last Name: Hjortnaes
Post by DHort » Sat Nov 12, 2022 12:13 am
I had my engine rebuilt by Adam and it leaks very little. This car has been to Detroit and back twice. I think he has a secret.
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Mon Nov 14, 2022 6:22 am
If you go to google maps and search for Greenfield village and tap the sattelite icon you can make out the regular route the museum Ts take by the very prominent oil trail these very well maintained T leave 😂
Leo van Stirum, Netherlands
Post by speedytinc » Mon Nov 14, 2022 8:25 am
The secret is attention to detail. A T can be made leak-less. REALLY. O-rings or seals on the transmission pedal shafts, ultra black on gaskets, modern seal on a correctly prepared crank & an added outer front neoprene seal, sealed bearings in the generator & starter plus a shaft seal.
Its a package & commitment. Complete leakness is possible, but may only last a few years until a drip or 2 shows up & needs to be chased & fixed.
A down side is the requirement of manually oiling the outside pedal cams. They can go dry, Gaul & no longer engage until again lubricated.
Post by TXGOAT2 » Mon Nov 14, 2022 10:31 am
Given the current price of motor oil, and the difficulty of keeping a leaky T halfway clean, I'd want to make every reasonable effort to build a leakless engine/transmission. A cleaner parking area and less chance of dirt and water intrusion would be worthwhile side benefits.
Post by Jerry VanOoteghem » Mon Nov 14, 2022 12:23 pm
On the other hand, I enjoy having my entire chassis automatically lubricated.
Hey... wasn't someone selling a Coupelet here??
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Sat Nov 19, 2022 5:01 pm
Incredible. A coupelet is offered for sale, and all that is discussed is leaking oil. Give me a break. Start a your own new thread about sealing up a T. Let's have a discussion about coupelets! Just sayin'. Bill
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Sat Nov 19, 2022 7:58 pm
I agree Bill. A very rare body style and no-one yet to make comment or observations about the car in question. It does have some very cool accessories a such as the Hayes wire wheels and the Stromberg OF carb but it seems that the 1917 body is mounted on a later model chassis and running gear as a study of the pictures shows this clearly. Would love to hear other folk knowledgeable about Coupelets make comment?
EricMac
First Name: Eric
Last Name: Macleod
* REQUIRED* Type and Year of Model Ts owned: 13 Touring, 26 Touring (2006 Stynoski), 27 Fordor, 27 Fordor, '92 Stynoski, 'owner emeritus
Post by EricMac » Sat Nov 19, 2022 11:05 pm
This little car is fantastic. If only to have space and funds when I need them!
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor (2)
1927 Touring
Post by Allan » Sun Nov 20, 2022 1:40 am
There's not a lot of 1917 about the running gear. Frame is 22 0r later, motor with generator 19 or later, Aftermarket honeycomb radiator. It may be a rare and desireable body style, but the rarity premium is gobbled up by the mishmash of later parts. I do like the Hayes wire wheels though.
Post by Jerry VanOoteghem » Sun Nov 20, 2022 8:27 am
Can you share what makes the frame a '22 or later? Is it the runningboard brackets?
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Sun Nov 20, 2022 5:51 pm
Allen, no offense intended, but I don't see a later running board brackets or a later driveline housing as having any effect on price of a driver car, especially a black-era driver car. In the US, loose stock T chassis parts for 1917-1921 cars have typically have little to no current value. Unfortunately, many now go to scrap. Or are almost free or free for the asking.
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Sun Nov 20, 2022 7:48 pm
John, Allans point is correct. The car is advertised as a 1917. If the body is indeed an original or even correct 1917 it should have period correct running gear underneath it. A 1917 body with all later model running gear underneath it is a mix up of parts, and I expect as Allan does that to match it up with all the correct production 1917 chassis and engine parts would be a costly and time consuming exercise.
Post by Jerry VanOoteghem » Sun Nov 20, 2022 9:20 pm
What car restoration isn't a costly and time consuming exercise? 1917 chassis parts are relatively abundant. 1917 Coupelet bodies... not. Besides, who says it can't be thoroughly enjoyed pretty much as-is?
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Mon Nov 21, 2022 5:27 am
I will gladly provide a set of factory wheels, rear end, engine, carb, water pump, motometer, radiator, rtc that are factory 1917 in exchange so you can bring it back to stock without accessories. Best thing for someone is to get it and have fun putting it back on the road. We know it isn't that hard to put together a chassis so over time should a new owner decide to bring it back to factory they could take the time to build a complete chassis and then in a day just move the body onto it.
Post by Allan » Mon Nov 21, 2022 6:21 am
Briefly, the pressed steel running board supports on our Canadian sourced cars first appeared in 1922.
The value of the vehicle is dependent on its true description. A 1917 couplet is of considerably more value than a 1917 couplet body on a 20's model running gear. Sure, the car may be a good driver, and it might be just the ticket for certain people, and could be enjoyed just as much as a true 1917 car, but that does not mean it is worth the same. Given that correct parts can be accumulated over time, that takes time and not inconsiderable expense in labour.
One would need to find a correct frame, running engine and transmission assembly, fan assembly, horn, horn button, front spring shackles, over axle front wishbone, front spring perches, headlight lenses, tie rod, rear radius rods, driveshaft tube, muffler, rear spring etc, etc, etc, for no cost and with labour to do the reassembly thrown in. Surely this has value, which needs to be taken into account when assessing the value of such a car. If you can find all this, and do the work, all for nothing, go for it. You can afford to pay the price for a known, correct 1917 model Couplet.
Post by Jerry VanOoteghem » Mon Nov 21, 2022 9:49 am
Excellent! Now go find another, better, 1917 Coupelet. ;)
1913Runabout
First Name: Brian
Last Name: Harlamoff
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
Post by 1913Runabout » Mon Nov 21, 2022 4:00 pm
I really like this car and would own it. Like others, I would search out all the correct 1917 parts to make the car truly a 1917. The main problem with this car is the vinyl top, the Naugahyde upholstery. Correct upholstery will be a non trivial cost. I see rust coming through the paint in places. For the asking price, I will seek out a better car or live with different body style. Brian
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Tue Nov 22, 2022 10:08 pm
So, lots of silly discussion.
The cheapest way to put a correct chassis under it: buy a good running correct 17 Touring or Runabout, swap the bodies, sell the other.
But you could have tons of fun driving the wheels off a 17 Coupelet until you find the donor! This is likely the only example you will see for sale for a decade or more!
Lots of people expressing interest and complaining. Has anybody just called Rob and made an offer?
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Sat Dec 10, 2022 11:04 am
Still there. Someone needs to make and offer.
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Fri Dec 23, 2022 8:46 pm
I guess its still for sale. Why wont somebody just make an offer?
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Fri Jan 13, 2023 6:11 pm
I havent seen a Coupelet out in the world in many years! This one needs an owner that will run it on tours all over!
Post by Jerry VanOoteghem » Fri Jan 13, 2023 6:51 pm
I really thought this would sell quickly. As David says, go ahead and make an offer. I have no stake in this at all, I'd just like to see it at least cleaned up and used. It's a cool car!
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Sun Jan 15, 2023 6:45 pm
It IS a cool car. I think the asking price is just too much for only an authentic body, though. The later running gear is what is hobbling this sale. Nobody wants to pay $24,000 for a body that is worth $10,000 and a chassis that's worth $2500.
And then have to build a 1917 chassis up, to put the body onto, on top of it.
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Post by Scott Rosenthal » Mon Jan 16, 2023 9:31 am
I spoke with the late owners son who is selling this and the rest of what is a fairly sizeable collection. He comes across as car savvy, not pressed to sell, and not niave to give it away. He has been receiving offers, because mine was one of them. As to moving this to a resto project, agreed, this is an approximately 10K body, sitting on a hodge podge of nominal value parts. Rims and Ruckstell may be 4K, if the Ruckstell is in safe operating condition. Mechanical condition of car is not known, and so not committed. As to finished value to me, that estimate includes thst it is the last year of this unique body style. That it is not a brass car, may lessen value to some...IMO, the painted radiator compliments this body design.
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Wed Jan 18, 2023 11:34 am
Back to the top.
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Sat Mar 04, 2023 12:09 pm
Back to top.
Guys, make him an offer.
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Fri Mar 17, 2023 9:30 am
Back up top. Please make him an offer!
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Sun Mar 19, 2023 9:39 pm
Price reduced. Make an offer!
Sarikatime
Last Name: Seress
Post by Sarikatime » Tue Mar 21, 2023 12:27 pm
I like the car and would be happy to own it but how do you get rid of all the mold that is all over the interior and who knows how much more underneath that you cannot see.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Mar 21, 2023 1:06 pm
The mold can be removed and eradicated without too much problem. I’ve had several cars that had mold from sitting when found.
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Tue Mar 28, 2023 6:47 pm
Back to the top.
Make an offer!
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Tue Mar 28, 2023 6:50 pm
The owner also has an unrestored '16 Runabout available. That would be a perfect donor chassis for this car.
Dliepelt
First Name: David
Last Name: Liepelt
Re: FS 1917 T Coupelet - Price Reduced
Post by Dliepelt » Thu Apr 13, 2023 12:33 am
Back to top
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Wed Apr 26, 2023 1:46 pm
STILL FOR SALE. VERY RARE MODEL.
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Tue Jul 04, 2023 10:02 am
I just cant believe nobody has jumped on this! I remember the first Coupelet I ever saw at Hershey. And Bill Barth used to run his quite a bit on tours. People were always hanging around them all excited!
Nobody cares anymore? It is so sad.
fordt
First Name: Rob
Last Name: Trippet
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU (in progress)
Post by fordt » Tue Jul 04, 2023 9:25 pm
Bring it Arizona! A couple weeks out there in 107°/5% humidity and voilà…mold gone!
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Fri Jul 07, 2023 9:07 am
Windex will clean it rite up.
Post by Jerry VanOoteghem » Fri Jul 07, 2023 11:36 am
I sure as heck wouldn't let mold stop me from buying any car that I had any desire to own.
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Sun Jul 09, 2023 4:18 pm
The people who are getting lost in mildew and oil drips and the wrong engine are also people who will never be able to get thru the "Elephant Eating" effort that is a restoration.
One person said its a $10,000 body on a $2,500 chassis. Precisely! With a $1,500 Ruxtell and a $2,000 set of wire wheels and hubs. And its all in one piece!
I truly thought there would be a rush for this car. The world is different today.
Would somebody please just call Rob and make an offer?
Post by Scott_Conger » Sun Jul 09, 2023 5:54 pm
So, it's a $16,000 car that is for sale at $19,500, and needs a 2nd car purchased to donate parts to build it up right.
It's an interesting car, and like Jerry, I wouldn't pass it up for having mold...but I would pass it up for sheer economics. I don't see a good reason to imply that folks are crazy to pass it up. That car just isn't for the average guy, especially when that kind of dough will buy a darn nice earlier brass T that is 5 years off of a good restoration.
Different strokes for different folks.
JvanMaanen
First Name: Jim
Last Name: Van Maanen
* REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
Post by JvanMaanen » Sun Jul 09, 2023 11:18 pm
Remember, for most it is a hobby, if you start trying to get a return on your investment, it is now a business, a whole different ball game.
Van
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Tue Jul 18, 2023 4:10 pm
Up to the top
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Tue Jul 25, 2023 12:23 pm
Back to the top
Dliepelt
First Name: David
Last Name: Liepelt
Re: FS 1917 T Coupelet - Price Reduced - Updated
Post by Dliepelt » Sat Aug 05, 2023 5:50 pm
Back up top
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Mon Aug 14, 2023 4:18 pm
Back up top
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster’s,51 Mercury 4 door sport sedan, 67 Mercury Cougar
Post by kmatt2 » Mon Aug 14, 2023 9:00 pm
I don’t know anything about this particular car because I live on the west coast. I would find out if the car had been in a flood, because that could cause all the wood framing to swell and then shrink when dry, which may cause some splitting of the wood. Fresh water may be ok but salt water could be a real problem.
In another point I remember a Vintage Ford story about a original late 1917 or 1918 removable pillar coupe that two sisters bought new in 1917 and in 1922 they had the Ford dealer swap the coupe body onto a new 1922 chassis with a starter. In the 1970’s when the sisters passed away the 1917 or 1918 flat roof coupe on the 1922 chassis was still in their garage.
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Wed Aug 16, 2023 1:33 pm
Been stored in a dry garage on high ground for 50+ years. Cant figure out what would lead you to even posit that situation.
kmatt2
First Name: Kevin
Post by kmatt2 » Wed Aug 16, 2023 5:07 pm
That is good to know that the car has always been in dry storage, all that mold came about for some reason .
Dliepelt
First Name: David
Last Name: Liepelt
Post by Dliepelt » Wed Aug 16, 2023 8:03 pm
2 years ago house behind the building it is in caught fire. Fire fighters soaked back of the building for several hours. It got humid inside. Owners son didnt get the front doors opened up in time. There is mildew on vinyl upholstery. Car was never wet. Building was humid for a few days.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Mon Jun 17, 2024 8:54 am
This one still for sale? Saw it somewhere else and asking price was down again.
