I just came across this on Hemmings.
https://www.hemmings.com/classifieds/li ... co-2788119
1915 Touring on Hemmings
Topic author - Posts: 216
- First Name: Bryan
- Last Name: Ostergren
- * REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
- First Name: Michael
- Last Name: Peternell
Re: 1915 Touring on Hemmings
That would seem to be a very fair price.
- Last Name: Humble
Wow, if I was closer...and needed another model t...
- First Name: Austin
- Last Name: Farmer
Radiator is worth half that alone!
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Is an old radiator like that which is likely on its 'last hurrah' really worth that much?
I applaud the Seller for realizing what this car isn't and pricing it accordingly. As I was looking at that car, do you suspect it is too far deteriorated to even be brought back as a 'survivor'? I'd say the body wood and sills are shot, and maybe the same for the top bows (-and maybe irons too)? I would think the car likely needs the rear axle gone thru to change the thrust washers, and the fuel system replaced due to rust, ...and the wheels respoked, likely rims replaced, and definitely something newer than those Non-Skid tires & tubes. Probably better factor in a new radiator, and some motor work. When you add it all up, it really needs a lot of labor and money spent on it where it can reliably Stop, Start, and Steer.
