FS Colorado titled as CV "Convertible" using VIN on frame. RAJO 8 plug, Scat 4.25 drilled, full pressure, Bosch front plate with 8 plug distributor, 3" exhaust with cutout. New Warford, 4 to 1 gears, frame boxed, Z'd, X'd shortened, front axle moved forward, 5 T wire wheels. Custom built body, seats, gas tank, frameless Duval style windshield, early '23 radiator and shell with stone guard. Stewart Warner vintage style gauges. The list goes on...
Featured in "Secrets" speed and sport magazine in July 2015. Also seen at Speedster reunion in Lincoln in 2015 and 2021. Hot Rod Hill Climb in Georgetown Colorado. There is a video online. Sorry Pics not loading. Chuck 10A to 2P 720-289-2896 Asking 20K
1926 speedster / racer for sale
- First Name: David
- Last Name: K
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster
Re: 1926 speedster / racer for sale
Can you post a link to the video? Thanks.
- First Name: Chad
- Last Name: Azevedo
This one I take it?
https://www.museumofamericanspeed.org/u ... 1_orig.jpg
Topic author - Posts: 18
- First Name: Charles
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pickup 1926 racer
- Board Member Since: 2002
If you search "Hot Rod Hill Climb" 2015 Georgetown Colorado is where to find the video. It will be the car posted by Mr. Azevedo. Thank you Chad! My IT person is coaching a Junior swim meet today. I have sent a number of pics via text here and there and am happy to do so. My availability after 2 PM Colorado time gets sketchy due to variable work commitments. I will reply to all asap.
The car will be at the 2025 Speedster reunion in Lincoln NB next week. I've received more interest East of Colorado than West and after thinking over a couple of my conversations with interested parties Lincoln will be a good fit. As always communicating by phone only 720-289-2896 lots of pictures via text and components list via email.
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up, 1924 PACO Bodied Speedster
Chuck asked me to post this and some pictures for him. His telephone # is at the bottom of his original post.
1926 Speedster
Chassis:
1926 frame boxed, Z’d, X’d, shortened 2 ¾”, powder coated 60% gloss
1926/7 front axle with smile, straightened, bushing contacts machined PC’d
1926/7 spindles with plates for disc brake adapter, new bushings, new roller bearings, sleeved to fit modern tie rod ends PC’d
Front brakes are from KZ1000 motorcycle mated with T-6 aluminum adapters and .1875 mild steel rotors drilled for holographic speedometer
Tie rod and drag link made from dom ¾” seamless tubing with modern rod ends PC’d
Front spring ‘26/7 with leaves removed, bronze bushings, PC’d
Front spring perches are ‘25 and earlier rear spring perches PC’d
Batwings owner designed/fabricated to drop axle and move forward 2 3/4” Grade 8 bolts custom machined PC’d
4 Bar front link system dom ¾” seamless tubing, grade 8 bolts, PC’d
Center to right side panard for l to r stability in hard turns
‘26/7 Rear axle, backing plates manufactured for 55-7 chevy hydraulics drumbs cylinders etc. 10 tooth pinion running in modern bearing, floating hubs, new drive shaft, torque tube shortened for modern Warford, 2 sets of radius rods, one to perfectly square ring and pinion and the other to fasten to chassis. Note, locating rods are set to pivot at the driveshaft ball.
‘17 and earlier rear spring one leaf removed, bronze bushings, PC’d
Frame to rt. spring hanger panard bar for l to r stability PC’d
Steering box is aftermarket Vega.
Wilwood master cylinder 7/8” with f and r check valves, proportioning valve and stoplight switch
Engine:
Serial number indicates it was cast after regular Model T Production
Bored 030 over, Egge pistons, cast iron rings
Scat crank drilled for pressure
Insert bearings with brass thrusts
Aftermarket A rods with inserts
Flywheel lightened
Complete rotating assembly balanced
Datsun B-210 oil pump
Bosch front plate with Datsun electronic distributor for duel spark plugs
Deep sump oil pan with return to T pan
Reproduction RAJO head kit
Stromberg 97 Carb also spare Stromberg 81 carb. with fittings for quick swap, K&N air filter by owner, Intake warmed by engine oil routed to rocker arm log
Transmission:
Needle bearing triple gears, new starter ring gear, Kevlar demount-able bands,
turbo 400 clutch discs, new pedal cams and shafts, lint catcher with magnet. Sealed ball bearing fourth main.
Fuel delivery:
Custom gas tank 18+ gallon capacity. Inside coated to prevent rust. Large capacity fuel filter, Holley “blue” fuel pump, all fuel lines made for use with alcohol fuel. Holley 0-4 Lb pressure regulator, Fuel pressure gauge going to carburetor, Gross jet into Stromberg 97.
Body:
Built of 20ga steel and ½” square tubing mounted to 1cm thick Baltic birch floor bolted directly to frame. Seats custom built from 18ga steel and Baltic Burch. Hood and louvered side panels are 20ga. Seats have built in lumbar support for 6’ driver and 5’ 7” passenger. Ford logo seat belts. Duval styled windshield w/safety glass, works best 45 mph plus!
Cooling:
New 17-23 radiator “short”, built with under hood fill and outlet moved 1 ½” toward center. Temp probe and electronic fan switch sensor installed. Electric fan, seldom comes on. Custom rock guard made of ½” square wire.
Lighting:
Front and rear turn signals both LED, rear brake and running light are also LED. Headlights are ‘26 mounted to stubby front fender brackets, halogen bulbs, not currently installed. All interior gauges are lighted.
Not installed but comes with car: Spare re-manufactured distributor, needs to be adapted to Bosch front plate. Complete rebuilt Stromberg 81 carb. with 2 air filters new gaskets accelerator pump etc., Spare new coil, new rear axle bumper, spare parts for electric fan, silicone mold for replacement rear turn lights. Stubby exhaust pipe 3” by approx 14”. Masonite windshield patterns. New spare gaskets for RAJO head and rocker cover. Stromberg x2 jets plate 33 to 46 plus a few extras. ‘26 Headlights mounted to stubby fender braces, Halogen bulps, new reflecters. Near new HJC full face helmet CL-17 less than 1 hour use. Spare alcohol resistant fuel line, header wrap, New 1” oil pan to sump hose. #2 an bypass oil line from pump to rocker log. Custom 1 1/8” id. intake manifold. Four medium sized multi compartment cases with carburetor, fuel, lighting, brake system small parts. Spare oil filter, Louvered hood side panels with fasteners.
1926 Speedster
Chassis:
Engine:
Flywheel lightened
Transmission:
Fuel delivery:
Body:
Cooling:
Lighting:
