26 Tudor For Sale "PRICE LOWERED"
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Mon Jul 21, 2025 1:27 pm
Selling my 26 Tudor. The driveline is earlier, Nov.1919 by the engine number. Older restoration, not a show pony, runs and drives good.
Engine has aluminum pistons/transmission has Kevlar bands.
$8000 or best reasonable offer.
List of items I replaced over winter.
Rear axle/driveshaft rebuilt, housings were only things not replaced.
New axles
Driveshaft
Modern spool assembly
New U-joint
AC Brakes/equalizer cables
Wire wheels
New tires, tubes, flaps
New Brassworks Radiator
New water pump
Fan hub/sealed bearings
6volt alternator/voltage regulator
6volt starter solenoid
New starter bendix
Transmission screen filter
Foot throttle
Fuel shutoff/Sediment trap
New ignition switch/ammeter
Outside mirrors
Shrshot
First Name: Kent
Last Name: Palazzo
Re: 26 Tudor For Sale
Post by Shrshot » Sun Jul 27, 2025 11:43 am
To the top
First Name: Austin
Last Name: Farmer
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by 1925 Touring » Sun Jul 27, 2025 1:14 pm
Sorry to hear you are selling your T!
Good luck with your sale!
Wingnut
First Name: William
Last Name: Reep
* REQUIRED* Type and Year of Model Ts owned: 1924 roadsters, 1926touring
Post by Wingnut » Sun Jul 27, 2025 2:10 pm
check your email, thanks
Wingnut
First Name: William
Last Name: Reep
Post by Wingnut » Sun Jul 27, 2025 2:24 pm
Is the diff. a 26-7 or earlier
Post by RajoRacer » Sun Jul 27, 2025 4:12 pm
Appears to be a small drum w/wires & outside brakes.
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Sun Jul 27, 2025 6:19 pm
Good eye Steve. Yes it is a small drum with AC brakes.
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Sun Jul 27, 2025 6:20 pm
Earlier diff. small drum with AC brakes. Everything is new except the housings.
Wingnut
First Name: William
Last Name: Reep
Post by Wingnut » Mon Jul 28, 2025 8:00 am
You mention a 1919 engine, does it have the narrower transmission brake band then.
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Mon Jul 28, 2025 2:43 pm
Yes it does, and the early style pedals too. The brake band is still hooked up, but I backed off the adjustment when I added the AC brakes. This way the wheel brakes do the stopping. The trans band will apply should the AC brakes fail. The brake cam will apply the band when the pedal is almost to the floor as a safety.
Shrshot
First Name: Kent
Last Name: Palazzo
Re: 26 Tudor For Sale "PRICE LOWERED"
Post by Shrshot » Sat Aug 02, 2025 10:03 am
Price lowered $8000 or best reasonable offer. I hate to part with it, but really need the garage space.
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Mon Aug 18, 2025 3:40 pm
To The Top...
