26 Tudor For Sale "PRICE LOWERED"
Topic author - Posts: 94
- First Name: Kent
- Last Name: Palazzo
Selling my 26 Tudor. The driveline is earlier, Nov.1919 by the engine number. Older restoration, not a show pony, runs and drives good.
Engine has aluminum pistons/transmission has Kevlar bands.
$8000 or best reasonable offer.
List of items I replaced over winter.
Rear axle/driveshaft rebuilt, housings were only things not replaced.
New axles
Driveshaft
Modern spool assembly
New U-joint
AC Brakes/equalizer cables
Wire wheels
New tires, tubes, flaps
New Brassworks Radiator
New water pump
Fan hub/sealed bearings
6volt alternator/voltage regulator
6volt starter solenoid
New starter bendix
Transmission screen filter
Foot throttle
Fuel shutoff/Sediment trap
New ignition switch/ammeter
Outside mirrors
New axles
Driveshaft
New U-joint
Wire wheels
New water pump
New starter bendix
Foot throttle
Outside mirrors
- First Name: Kent
Re: 26 Tudor For Sale
To the top
- First Name: Austin
- Last Name: Farmer
Sorry to hear you are selling your T!
Good luck with your sale!
- First Name: William
- Last Name: Reep
- * REQUIRED* Type and Year of Model Ts owned: 1924 roadsters, 1926touring
check your email, thanks
- Last Name: Reep
Is the diff. a 26-7 or earlier
Appears to be a small drum w/wires & outside brakes.
- Last Name: Reep
You mention a 1919 engine, does it have the narrower transmission brake band then.
- First Name: Kent
Yes it does, and the early style pedals too. The brake band is still hooked up, but I backed off the adjustment when I added the AC brakes. This way the wheel brakes do the stopping. The trans band will apply should the AC brakes fail. The brake cam will apply the band when the pedal is almost to the floor as a safety.
- First Name: Kent
Re: 26 Tudor For Sale "PRICE LOWERED"
Price lowered $8000 or best reasonable offer. I hate to part with it, but really need the garage space.
- First Name: Kent
To The Top...
