1925 Model TT Fire Department Hose Wagon
wll17057
Topic author - Posts: 2
- First Name: William
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 1919 Roadster, 1925 TT
Located Middletown PA near Harrisburg PA Intl Airport. I have owned the Hose Wagon in excess of 6 years. Found in a used car lot. Wooden hose bed had deteriorated because of weather. The hose bed floor and frame rails have been replaced with new oak. Sides and front wall of bed are assumed to be original as are brass hand rails. Entire metal chassis is in solid shape. Lights work. Brake lights have been added. 6-volt electric siren works. Electric start. Vehicle has been "rebuilt"...hose bed body repainted as well as metal step boards, fenders and engine hood. Runs fine on battery...magneto is inoperative. Kept indoors the past six+ years. Tires are old and should probably be replaced (although tread is ok). Vehicle includes approximately $3,500-$4,000 in period correct, vintage hand equipment (proper electric siren, one ground ladder, multiple chemical extinguishers, multiple brass nozzles and play pipes (1 1/'" and 2 1/2"), several vintage helmets, Dietz Fire King lanterns and pike poles. Brass spot light recently added but has not been wired for operation. Miscellaneous hand tools. American LaFrance mfg. plate on hose bed side wall BUT clear title makes no reference to ALF, only Ford. Chief's Helmet and hand crank shown in photos are NOT included. Will not sell equipment separately. $13,500. Bill @ wll17057@comcast.net
wll17057
Re: 1925 Model TT Fire Department Hose Wagon
The Hose Wagon is sold. It went to a good home in Central Pennsylvania. The new owner has a Model T and the first two fire engines from his community. So...a perfect fit...a Model TT and a FD Hose Wagon. Thanks to everyone who looked at the advertisement.
Retro54
- First Name: Andrew
- Last Name: Blaydon
Congrats! Sorry I missed this add, would have checked it out. I must be near you in Lower Swatara. Maybe we'll cross paths some day. Feel free to reach out if you want.
