1924 Ford Model T Runabout for Sale
This car was restored by my father in-law back in the 1990’s. It was given to me after his passing in 2004. At the time it needed some work to get it running, which I have since completed.
Specifics:
1924 Runabout body with cloth top. The body and paint are in great shape with the usual nicks and chips here and there from being in storage for several years.
I believe it is a 1921 engine (S/N 53,465,530). It has a new Holly NH carburetor with center drain and new fuel line sediment bulb. New radiator hoses and inlet and outlet connectors. 6-volt battery, with 6- volt sealed beam headlights, rear brake light and electric starter. The engine starts and runs but could use some carburetor or timer adjustment.
New rubber mat and the upholstery is in great shape. It has late model Ford wire rims with larger tires.
As most T owners do…I have a few extra parts such as a new stainless steel water pump.
Lots of pictures if requested. Registered in Washington (clear title).
Motivated to sell. I can assist with vehicle transportation within the Puget Sound Region.
-- SOLD --
