FOR SALE: 1914 Model T Ford Speedster
GatorsModelT
First Name: Eric "Gator" & Paula
Last Name: Gould
* REQUIRED* Type and Year of Model Ts owned: 1915 Southern Wide Track Touring, 1918 Couplet, 1919 Canopy Express,1920 Center Door Sedan
Board Member Since: 2003
Post by GatorsModelT » Mon Nov 20, 2023 10:00 pm
For Sale: 1914 Model T Ford Speedster. 12 Volt System, Freshly rebuilt Motor. Has New Scat Crank, New Rods, New 290 Stipe Cam & Bearings, adjustable lifters, New Aluminum head, 390 Ford Valves, Ceramic coated Header with Down-Draft Solex Single Barrel carburetor. Balanced Flywheel. New 12 Volt Gear Drive Starter. Has distributor. New Layne Auxiliary Transmission, New Turbo 400 Clutches. Original transmission has been rebuilt. Has Disc Brakes, Free Floater Hubs, Wire Wheels, Lowered Rear End, has Drop Front Axle, New Front Spring. Also has turn signals. Has been driven 127 miles since rebuild. Owner passed away and Widow must sell $14,500. Contact Eric "Gator" Gould for more details. 251-765-2677 Monroeville, AL
