F.S. 1915 model T touring
Topic author - Posts: 701
- Last Name: Seress
I bought this 1915 touring five years ago, since then I had most of the repairs done and new parts installed within the last year or two.
- Had the motor and transmission professionally rebuilt with about two thousand miles on it since,
New aluminum pistons, new valves and seats, 280 cam, new Babbitt, re ground crank, new intake and exhaust
manifolds, new ring gear for the starter, rubber seals on the pedal cams, resurfaced head and
the block, outside oil line to the front of the motor.
- Five new tires, tubes and flaps installed on demountable rims. Spare tire bracket in back.
- LED lights all around, driving, directional and brake lights.
- New top upholstery.
- New seat and side panels.
- New front tapered leaf spring.
- Rebuilt front axle.
- New gas tank and sediment bowl.
- Rebuilt NH carburator
- New brass flat tube radiator three years ago.
- Safety glass in front windshield.
- Tool box on running board.
- Aluminum step plates.
- New Day timer.
- Recently repainted the fenders,splash shields and running boards.
- Cut off to power switch with key.
- Kevlar bands, new.
The body has older paint and bumps and dents that could be taken out if you wish but I thought it gave it an old car flavor that I like. This is definitely a nice driver which got many waves and thumbs up on many tours, more thumbs up than the shiny expensive paint jobs.
It is not a perfect car but a good running solid driver.
A new timing gear was installed with the motor rebuild but it makes a little noise.
Come and take it for a drive in Prescott Arizona, up in the hills. $ 12,950.. or best offer
Frank eight one eight two five four six seven nine seven
Call or text
sarikatime@yahoo.com
- New Day timer.
Call or text
- Last Name: Seress
Re: F.S. 1915 model T touring
More pictures
- Last Name: Seress
This car has rebuilt motor and transmission, 12 volt system with starter and alternator, new tires on demountable rims, rebuilt wood spokes, new interior and top, brake and directional lights, and much more.
Bought a nother model T and need the space in the garage.
It is ready to tour, already has everything, not ready for rebuild like most others for sale.
- Last Name: Seress
Trade for a nother model T may be considered.
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- Board Member Since: 2013
I have a Speedster that I would trade. The car is apart and ready to put back together. It has a 26/27 engine with an A crank with a counter balanced crank and an 8 valve Roof head. Tom nine28-305-547five
- Last Name: Seress
Tom, thank you for the offer to trade model T’s. I am not looking for a project or a speedster, sorry. Would like to have a nother brass model, maybe coup or centerdoor. Coupolet would be the most ideal. The ruckstell you sold me is working just fine. Frank
- First Name: Tom
Thanks Frank:
Its always nice to hear from other Model T people the I have sold parts to.
Tom
Tom
- Last Name: Seress
To the top
- Last Name: Seress
To the top
Just a suggestion, but maybe you should state just what has been removed. For instance, you no longer mention Rock Mtn. brakes, but the pictures still show them. Are they still there or not?Sarikatime wrote: ↑Sat May 10, 2025 12:31 pmI have removed some parts from the car in able to lower the price because I have way over asking price and my time in the car. Read original first post to know what is included in the sale.
- Last Name: Seress
Jerry, I removed the oil and gas running board boyco cans, and will be removing the ruckstell rear axle since I live at 5500 feet elevation and there is only hills in my area including my driveway. I am installing a standard rear axle. I repainted the fenders and running boards due to some scratches I didn’t like.
- Last Name: Seress
Still available.
- Last Name: Seress
Please ONLY email me for information because I will be out of the country till September 27.
I won’t be able to use the phone or text there.
