FS- New Rocky Mtn. 6 Speed Countershaft
Dan McEachern
Topic author - Posts: 1512
- First Name: DAN
- Last Name: MCEACHERN
For Sale- new countershaft for Rocky Mountain 6 speed auxiliary transmission. I had to make one for a transmission I'm working on so I made an extra.
These are chrome-nickel steel carburized and ground to size. If you have a Rocky Mountain transmission, these shafts are usually worn. $145.00 plus shipping. PM or dmcgearsatyahoodotcom. I can also deliver to Bakersfield swap meet. thanks, Dan
Rick_Rice
- First Name: Rick
- Last Name: Rice
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Closed Cab Express
Re: FS- New Rocky Mtn. 6 Speed Countershaft
Hi Dan,
I sent you a PM.
Kind Regards,
Rick Rice
I sent you a PM.
Kind Regards,
Rick Rice
Dan McEachern
- First Name: DAN
Rick- I have replied to your PM. Dan
jburns79se
- Last Name: Burns
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster
Dan,please call 409-962-2643 if still available or if your source could produce two more. Number is home phone with recorder if I am not home.
Dan McEachern
- First Name: DAN
James- I'm the source of the shafts. I can make more, but they would need to wait until I have a load of parts going to heat treat unless someone wanted to pay the freight to heat treat just a few shafts. I made these because I had a transmission that needed a new shaft, and I did not want to sell it with a worn shaft. I'll have the transmission at Bakersfield for sale. I'll try to call you or you can e-mail me at dmcgearsatyahoo.com
Rick_Rice
- First Name: Rick
- Last Name: Rice
Hi Dan,
To confirm, sent your check out two days ago for the shaft. Please confirm when you have received it.
Kind Regards,
Rick Rice
Kind Regards,
Rick Rice
Dan McEachern
- First Name: DAN
bump- I have two of these left on the shelf.
Dan, it's a great service that you have provided with these shafts. Thanks for all you do for our hobby.
