WTB American Bosch Distributor Parts
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sat Aug 13, 2022 7:54 am
I know it’s not easy but Iam looking for parts for the American Bosch distributor. Type T-448. Manly the distributor cap. Part#65942. Also any surviving information books on the distributor. Thanks
Tom VanMeeteren
Last Name: VanMeeteren
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1923 touring
Re: WTB American Bosch Distributor Parts
Post by Tom VanMeeteren » Sat Aug 13, 2022 9:08 am
Bryant, see my post in the General discussion regarding these dist caps.
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Aug 13, 2022 12:55 pm
Hi Bryant,
I have a cap in a little better shape than the one pictured. In the past I have used the drive & adapted to a 009 Bosch distributer Then if wanted can go to Pertronics electronic ignition.
Post by Mark Gregush » Sat Aug 13, 2022 6:06 pm
A point you might want to think about. Most of these old units, the shaft and bushings/body are worn. With wear, you change your cylinder firing as the shaft wobbles and the air gap between the cap and rotor changes. A car putting around at 35 or less, might not be much of an issue, but ideally you want that gap to stay pretty close to the same all the time.
SIR TIMOTHY
First Name: TIMOTHY
Last Name: ELDER
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout
Post by SIR TIMOTHY » Mon Aug 15, 2022 8:48 pm
I have this extra sitting on a shelf. tim
Post by Jerry VanOoteghem » Tue Aug 16, 2022 2:08 pm
Be careful. Caps for Bosch front plate distributors are not the same as caps for clip-on style distributors.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Tue Aug 16, 2022 3:04 pm
thanks for the heads up! I’ve been doing research till Iam blue in the face. Is this cap one for a clip on? I noticed a different part number and manufacturers logo.
Bryant
Post by Jerry VanOoteghem » Tue Aug 16, 2022 4:14 pm
thanks for the heads up! I’ve been doing research till I am blue in the face. Is this cap one for a clip on? I noticed a different part number and manufacturers logo.
Bryant
I believe the one shown by Sir Tim is for a clip-on. Notice how yours has a "male" locating lug, versus Tim's which has a groove for location.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Thu Aug 18, 2022 3:57 pm
Rolling The Dice 🎲 🎲
Looking for the oil cup for the distributor shaft. Attached to the outside of distributor housing.
Bryant
Post by TRDxB2 » Thu Aug 18, 2022 6:19 pm
It is not an "oil cup" but a "grease cup". Grease cups are designed to push grease into whatever
ab cup.png (233.79 KiB) Viewed 5693 times
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Thu Aug 18, 2022 7:18 pm
Here’s an example
I did see the clip on Bosch had the grease version. This distributor has to travel through an empty space about an inch. I think it may have had a wick. Thanks jerry for the pictures
Post by Jerry VanOoteghem » Thu Aug 18, 2022 7:35 pm
Here's another part to look for. It's a rare find though. Hard to make it out in the photo, but the thumbnut has the "AB" American Bosch logo cast into it. Obviously not a necessity, but kinda cool if you can find one.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Fri Aug 26, 2022 7:06 pm
Rolling the dice 🎲 🎲
Can I get a condenser? Anyone? Don’t be shy
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Aug 26, 2022 7:35 pm
The condenser does not have to be inside the distributor.
Follow that distributor wire to the coil and place the condenser there.
All those little round condensers with the pig tail wire are the same size as an early Ford coil condenser.
Some of the coil bands have a small area about 3/8th inch square with a tapped hole in it for a screw to hold the condenser band.
Look for one of those.
Tom VanMeeteren
Post by Tom VanMeeteren » Fri Aug 26, 2022 10:43 pm
Bryant, I have them NOS contact me again Tom
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Aug 28, 2022 9:08 am
sounds good email sent
Tom VanMeeteren
Post by Tom VanMeeteren » Sun Aug 28, 2022 1:21 pm
I have NOS point sets, rotors, resistance units and condensers available for the Bosch units. As mentioned before, no caps available at this time. Thinking about reproducing them, but still not enough interest. Included is pictures of the resistance unit and the condenser (if I finally got them loaded
Tom VanMeeteren
Post by Tom VanMeeteren » Sun Aug 28, 2022 1:22 pm
picture of the condenser
Tom VanMeeteren
Post by Tom VanMeeteren » Sun Aug 28, 2022 1:23 pm
darn condenser won't load
Tom VanMeeteren
Post by Tom VanMeeteren » Sun Aug 28, 2022 10:07 pm
[image][/image]3rd try on the condenser
Tom VanMeeteren
Post by Tom VanMeeteren » Mon Aug 29, 2022 7:16 pm
Condenser - try again :?:
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Mon Aug 29, 2022 7:28 pm
Hey Tom
What’s your price on the condenser?
Bryant
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Tue Apr 18, 2023 7:25 am
Trying to find the cam and distributor shaft gears for this unit..
Still looking for the oil cup
Bryant
Post by Jerry VanOoteghem » Tue Apr 18, 2023 8:45 pm
Bryant
Chaffin's Garage, page 47.
A little cheaper at Lang's...
https://www.modeltford.com/item/BO2.aspx
You might need this too?
https://www.modeltford.com/item/BO-LN.aspx
Post by TRDxB2 » Wed Apr 19, 2023 1:09 am
Hope this helps Not sure what the difference is in Models "Type FI-513" and "Type T-448"
Whats the issue with the cam?
The conversion PDF discusses some measurements and options.
Instructions & parts list FI-513.
1923boschmaginstmanual.pdf
(419.76 KiB) Downloaded 110 times
from the above
from your earlier post T-448
Points & your missing parts look the same as a Model 600
Conversion to electronic ignition
Conversion it electronis.pdf
(346.75 KiB) Downloaded 100 times
Paul-Geil
First Name: Paul
Last Name: Geil
* REQUIRED* Type and Year of Model Ts owned: 24 Tudor, 27 Touring, 27 RPU, 27 TT, 14 Touring, 16 touring, 11 Touring, 29 Model A 4-door town sedan, 31 Tudor sedan,
Post by Paul-Geil » Wed Apr 19, 2023 2:01 pm
Bryant, I have this Bosch distributor that I removed from a running T. If you’re interested, let me know.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Wed Apr 19, 2023 6:01 pm
Thanks Jerry! I think I’ve seen those before but wasn’t clear if they where for my distributor.
Thanks Frank for all the good info! The gears I have look to be repaired and I don’t think I will trust them.
Paul I sent you a email
Bryant
