Change the Starter Bendix drive gear with balance ring
Sanary22FT
First Name: Stephane
Last Name: Lezzier
* REQUIRED* Type and Year of Model Ts owned: Touring US 1918
Board Member Since: 2022
Post by Sanary22FT » Tue Oct 25, 2022 3:52 pm
Hello,
Can you know to change the Starter Bendix drive gear with balance ring
Item Number: 5021G
Thanks for help
My T 1922 Touring in France
Re: Change the Starter Bendix drive gear with balance ring
Post by speedytinc » Tue Oct 25, 2022 4:05 pm
The bushing on the end is threaded(RHT) Look inside where the starter shaft runs. Note the body hat 2 upsets.(one in each of the 1/8" holes)
Un divot those upsets. The bushing will unscrew.
The difficulty comes with grabbing the bushing & turning the body or visa versa. I made a special block with 2 1/8"pins to lock into the bushing & put a bolt into the body to grab. Thats 5/16 nf in the threaded spring anchor point in the body.
Post by DanTreace » Tue Oct 25, 2022 5:59 pm
Another way that can work is soft aluminum jaws in the bench vise to hold the collar as you rotate the Bendix screw. Punch away the two divots that locks the collar.
Thread a bolt into the the Bendix to use as a lever, a length of pipe adds to the ease, to turn the screw out of the collar.
Don't forget to re-punch the threaded shaft against the collar , to keep the collar locked there after the gear has been changed. (First photo)
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Oct 26, 2022 12:19 am
John & Dan,
Excellent descriptions gentlemen. What have you guys been doing for loose balance rings?
Post by RajoRacer » Wed Oct 26, 2022 12:25 am
I replace them - some folks like to braze or weld them tight again but I've not had luck with that remedy !
Post by speedytinc » Wed Oct 26, 2022 8:19 am
Press back into place & braze the contact points where the gear & counter weight meet. Very clean metal(bead blasted) Heat only small, specific areas, about 3/16" contact points to keep the gear from losing temper. At least 100 done this way. No issues. Never to get loose again.
Sanary22FT
Last Name: Lezzier
Post by Sanary22FT » Wed Oct 26, 2022 3:16 pm
Thanks a lot
