For sale; 290 cam for $290
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Oct 28, 2022 4:31 pm
Here is a used re-ground cam. I checked one lobe and it shows about .287” lift, so maybe that’s what they ground it to, or maybe it was originally .290 and has .003 wear. I have no idea who ground it or any other specifics. It was in an engine I bought for parts. Includes bearings in picture and the bronze rear bearing that was in the block with it. First $290 plus shipping gets it. Inside the USA only, please. Email if you want it. Include your address so I can figure shipping. I don’t get pm’s and might not see a post here. Thanks.
ModelTMark
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
Re: For sale; 290 cam for $290
Post by ModelTMark » Wed Nov 02, 2022 9:13 pm
Adam,
I don't believe that's how you measure the lift of a camshaft. It's a ratio calculated by the lobe nose to heel measurement minus the measurement of the base circle.
R/Mark
Post by Jerry VanOoteghem » Thu Nov 03, 2022 10:28 am
Adam,
R/Mark
If he zeroed his indicator on the base circle, then what he shows & states is correct.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Nov 03, 2022 11:01 am
Please ignore the comment by Modeltmark, he doesn’t understand what he’s looking at. Jerry did get it correct. Thanks Jerry. It IS exactly what it IS.
Tallpaul
First Name: Paul
Last Name: Allen
* REQUIRED* Type and Year of Model Ts owned: 1923
Post by Tallpaul » Sun Nov 13, 2022 10:32 pm
Adam, is your .290 cam still for sale?
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Mon Nov 14, 2022 10:26 am
Still available. $290 plus shipping gets it.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Tue Nov 15, 2022 4:37 pm
To the top
