Frame, axles, and engine -- assorted, Little Rock, AR $350
Walter Higgins
First Name: Walter
Last Name: Higgins
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
Post by Walter Higgins » Sun Nov 27, 2022 2:56 pm
As seen in the attached photos. The frame is nice. It was blasted and painted 20 years ago and kept inside. There is a '26 - '27 front axle assembly and a common one. Common differential with axles but no driveshaft. '26 - '27 engine block that has had a crack repair, '26 - '27 transmission that looks decent, narrow nose engine pan, and some other miscellaneous bits. It should be a good start to something for someone.
Whole pile, one money: $350
Message me through the system with your phone number and I'll call. Thanks!
Steve Behrendt
Last Name: Behrendt
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1925 Touring
Board Member Since: 2022
Re: Frame, axles, and engine -- assorted, Little Rock, AR $350
Post by Steve Behrendt » Fri Dec 09, 2022 11:28 pm
Are these parts still for sale? Call me at 620 two one eight 4 two 9 two. Thanks , Steve
