Wanted 7-leaf Taper Leaf Rear Spring
Carter
First Name: David
Last Name: Carter
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster, 1926 Modified
Board Member Since: 2010
Post by Carter » Tue Nov 29, 2022 2:40 pm
As the title says, I'm looking for a nice 7-leaf taper leaf rear spring, the closer to Western Pennsylvania the better. Would consider an 8 leaf also.
Thanks,
Dave Carter
Mark Nunn
Last Name: Nunn
Re: Wanted 7-leaf Taper Leaf Rear Spring
Post by Mark Nunn » Tue Nov 29, 2022 7:47 pm
Omaha craigslist has a frame with tapered rear spring listed. It has the riveted spring clip. Not my ad but maybe this helps.
https://omaha.craigslist.org/pts/d/omah ... 00546.html
dinosbunny
First Name: dino
Last Name: marinelli
Post by dinosbunny » Wed Nov 30, 2022 11:41 pm
I have a partial set, the bottom four, you can have for free if your interested, just pay shipping, you can probably pick up the last three easy or make them since they do not show to much
DustySpokes
First Name: Edmund
Last Name: Niedzielski
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Post by DustySpokes » Mon Jan 02, 2023 3:30 pm
Did you ever find the spring set ?
