drive shaft tap
TLeroux
Last Name: Leroux
Board Member Since: 2010
drive shaft tap
Post by TLeroux » Wed Feb 15, 2023 10:23 pm
WTB drive shaft tap 13/32x16 tap
tom
Last Name: Hatch
Re: drive shaft tap
Post by Dan Hatch » Thu Feb 16, 2023 8:44 am
I may have an extra one. I will look. Email me
Last Name: Hatch
Re: drive shaft tap
Post by Dan Hatch » Thu Feb 16, 2023 10:17 am
I don’t have an extra one.
I may look into making another batch if there’s interest. Dan
havnfun
First Name: Joe
Last Name: Kowalczyk
Re: drive shaft tap
Post by havnfun » Thu Feb 16, 2023 10:45 am
Dan, I’d like to buy one or two if you get them made
Regards,
TLeroux
Last Name: Leroux
Re: drive shaft tap
Post by TLeroux » Thu Feb 16, 2023 11:17 am
Dan
thanks I will buy 2 if you make them
tom
Re: drive shaft tap
Post by speedytinc » Thu Feb 16, 2023 11:33 am
Have you measured the OD of a 3/8-16 helicoil/thread insert tap?
If I was home I would measure one. If you dont have one, take your caliper over to Hilco.
Something in the back of my head spoke to me. They arent as hard to get as you would think.
Edit: Further investigation. The helicoil tap would be to big. It would work for a 7/16-16 bolt (Harley)
I gotta learn to ignore those voices.
Re: drive shaft tap
Post by Scott_Conger » Thu Feb 16, 2023 1:50 pm
Nothing wrong with trying to think outside of the box, John
Lemperesg
Last Name: Lemperes
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring
Re: drive shaft tap
Post by Lemperesg » Thu Feb 16, 2023 8:27 pm
Please excuse my ignorance but, what is a drive shaft tap used for?
Re: drive shaft tap
Post by RajoRacer » Thu Feb 16, 2023 8:45 pm
The axle housing halves have a "special" thread that the d.s. spool studs/bolts use
TLeroux
Last Name: Leroux
Re: drive shaft tap
Post by TLeroux » Thu Feb 16, 2023 9:37 pm
I will Checking on having some Made.
stay tuned
Re: drive shaft tap
Post by Scott_Conger » Fri Feb 17, 2023 9:53 am
Tom
don't bother
just sign up with Dan here: https://mtfca.com/phpBB3/viewtopic.php?f=5&t=34739
