Excess for my needs speedo gear and plate.
Both for $75.00 plus postage.
Thank You
Speedo parts for sale
Larry LaPatka
Topic author - Posts: 176
- Last Name: LaPatka
- * REQUIRED* Type and Year of Model Ts owned: 13 Pie Wagon, 13 Depot Hack,14 Bell Telephone Service Truck, 14 Delivery "C" Cab, 30 Model A Closed Cab
- Attachments
- 0A385E4D-30AA-45DD-B5B5-0A49675C93D5.jpeg (30.81 KiB) Viewed 1711 times
- 1662A0FF-285A-48A5-8360-B066BC6B1E9C.jpeg (29.95 KiB) Viewed 1711 times
Re: Speedo parts for sale
The top one is for AC setup and bottom one looks to be for Stewart. Because we cannot click on the images for bigger view, maybe more information would be in order esp on the No 2.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
The second gear is a reproduction Stewart gear. It appears to be a cast gear, not a machined steel one as there are no holes drilled in the gear for mounting. I hope this helps, Russ Furstnow
ModelTWoods
- First Name: Terry
- Last Name: Woods
Also, the first top gear, which is an AC is for wooden wheels only. A different gear, made exactly the same except a fourth tab and mounting hole were added, was used with wire wheels.
electfearless
- First Name: Freddie
- Last Name: Carver
Is it still available for sale?Russ_Furstnow wrote: ↑Sun Feb 26, 2023 9:30 amThe second gear is a reproduction Stewart gear. It appears to be a cast gear, not a machined steel one as there are no holes drilled in the gear for mounting. I hope this helps, Russ Furstnow funny shooter 2
1924 Model TT Truck
1930 Model A Pheaton
