Rebuilding a carburetor and this is the missing part
Thanks for looking
Double Venturi needed for 1928 zenith or holley
Re: Double Venturi needed for 1928 zenith or holley
This information was just posted on Fordbarn. You may be able to use a single venturi.
https://www.fordbarn.com/forum/showthre ... le+Venturi
I only did a quick read, did not see if Snyders still had any, they did in the past.
Checked lots of Model A sites Mikes $32 but doesn't indicate availability https://www.mikes-afordable.com/product/A9586A.html
Snyder's , Exckelr's, SNJ out of stock
